House Not Square To Driveway... - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 06-07-2013, 12:20 PM   #1
House not square to driveway...
Hello, I am paving the driveway on the side of the house with 6x9 pavers. I have a patio in the backyard which is square to the house. I plan on weaving in to the existing patio to run along the side. The problem is my house is on a pretty big angle from the side. If I do weave it will not square up to the outside edge of the driveway. I plan on keeping the side running straight as it is an extension of the driveway.
How can I run the pavers?
The only way I see it is if I cut the pavers on an angle. These cuts will sit about 4 feet away from the house towards one side of the driveway. Does this seem right? I am using the herringbone pattern.
sharp is offline   Reply With Quote
Old 06-08-2013, 08:27 AM   #2
Rewards Points: 236
pics ?
Fix'n it is offline   Reply With Quote
Old 06-11-2013, 12:58 PM   #3
Bill Kearney
Rewards Points: 1,174
You say 'big' angle. What do you mean? That where the lines meet it's a very sharp change? That would be a small angle. Or do you mean it's only a gradual, but noticeably un-square transition?
You might 'want' to use a herringbone pattern, but that may or may not work given the situation. Perhaps a border between the two areas would give a way to create a more pleasing looking transition from one to the other, even with a pattern change and not just the angle.
wkearney99 is offline   Reply With Quote
Old 06-11-2013, 01:09 PM   #4
MarginallyQualified
Rewards Points: 2,464
Why?
I plan on keeping the side running straight as it is an extension of the driveway. How can I run the pavers?
See? Trying to make all that 90 degree layout fit all over is tough.
I'll suggest some sort of transition material set with a different pattern altogether (or solid with no pattern like concrete) to finish the one area... and then "float" out to the second area where the other end can be formed as square as is needed to make the driveway work.
hth
Old 06-17-2013, 12:25 PM   #5
Thanks for the responses. I used a herringbone pattern throughout, no transition. When it comes to the portion the "straight" portion the pattern sits on a bit of an angle. A border was not possible and a transition would have too long of an area with angles cuts, which I felt would bother me more the the pattern not being square to the street.
Old 06-17-2013, 02:21 PM   #6
Bill Kearney
What, no pix?
Old 06-17-2013, 04:03 PM   #7
MarginallyQualified
My ex wife was a martyr like that too.
Originally Posted by wkearney99
What, no pix?
What he said.
How to repair a cracked driveway or walkway rfrick7@yahoo.c How To Guides 8 06-15-2015 03:59 AM
driveway slopes towards house bseries4life Concrete, Stone & Masonry 5 05-20-2012 11:00 AM
Attaching wood fence to house TheCowGod Building & Construction 5 04-13-2012 03:57 PM
Bad driveway patch and seal work fastfan Landscaping & Lawn Care 1 09-09-2009 08:14 PM
Question about convrete driveway Laser4G63 General DIY Discussions 8 02-12-2009 05:19 PM
