Hose Holder Suggestions Needed - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 06-26-2009, 11:23 PM   #1
Hose holder suggestions needed
What type water hose holder do you have and do you like it?
I've got a new patio and the frost free faucet is at one end. I want the best way to keep the hose put up without a lot of hassle or space.
I'm thinking mounting a hose reel to the brick wall behind the patio. (mount a wood board first and then the holder to that)
But there are so many options out there now: some even have some sort of water pressure hydraulic system that automatically rolls the hose up..
diyntn is offline   Reply With Quote
Old 06-26-2009, 11:29 PM   #2
strube1369
strube1369's Avatar
hose holder
We use one of those "box with a crank" type. Got it at Menards, I think. Keeps the hose out of the way, protected, and neatly stored. Works for us...
strube1369 is offline   Reply With Quote
Old 06-27-2009, 12:40 AM   #3
Rewards Points: 176
We have the 'box with a crank' type also. It's been great so far.
gma2rjc is offline   Reply With Quote
Old 06-27-2009, 09:20 AM   #4
so many choices, do you have a LOT of plants in pots that you need to water every day? If so, box will get tiresome and a loop over style of hanging decorative rack with a shorter hose is quicker and easier day after day. If not, then box is great! Some even look like stones, but don't have crank to coil. I have one of those hydro roll up things attached to a freestanding outdoor sink. Got it last year and it's still in the garage. Really got it for the sink, thought it would be great around the barbeque for a quick rinse.
I am curious to see some comments about the auto hydro roll.
Sasha2000 is offline   Reply With Quote
Old 06-27-2009, 04:06 PM   #5
Don't know it all, yet!
Why not just mount the reel to the brick? Just wondered.
I have a cart type reel but then I often use 150-200 feet at a time. I use a hose about twenty feet long (instead of the one supplied with the reel). That way I can roll the cart out past the back porch and pull straight out instead of pulling around and against the porch posts.
If it's worth doing, it's worth doing right. If you wouldn't put your name on it, it ain't done right!
downunder is offline   Reply With Quote
Old 06-27-2009, 04:12 PM   #6
Kap
Mowing my life away.
I got tired of dragging/rolling hoses. Anything more than 20 ft from a water source gets PVC run to it with a hose bib or quick connect.
Kap is offline   Reply With Quote
Drain hose stuck on washing machine savingedmund Plumbing 3 05-10-2009 11:19 AM
Drywall primer suggestions needed... MT Stringer Drywall & Plaster 4 10-21-2008 11:25 AM
suggestions needed sjthszn Flooring 1 10-03-2008 12:33 AM
Suggestions Needed - Laminate on Staircase Bob_Zahn Flooring 6 05-13-2008 11:11 PM
garden hose water spillage questions mcvane Landscaping & Lawn Care 10 07-29-2007 01:27 AM
