Hose Fittings - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 05-28-2010, 09:36 AM   #1
Hose fittings
I sort of installed a soaker hose this morning and had to cut it to length and install a new fitting on the end which was easy enough - however it now leaks like the dickens at the new fitting (oh the irony.) Is there something I can do to help seal up the end a bit more so the water actually soaks what I want instead of flooding the end the fitting is on? Would pipe dope or teflon tape do the trick in this case?
cellophane is offline   Reply With Quote
Old 05-28-2010, 03:59 PM   #2
Don't know it all, yet!
Can you just cut the end off and re-install? Is this a recycled rubber hose that weeps or a drip irrigation hose with pre-made holes?
If it's worth doing, it's worth doing right. If you wouldn't put your name on it, it ain't done right!
downunder is offline   Reply With Quote
Old 06-01-2010, 09:50 AM   #3
It is a recycled rubber weep hose. I'll try to re-fit it tonight, although it occurred to me since I posted the first time, a fitting that actually covers the hose instead of a crimp fitting it might work out better.
The fitting I used is similar to this one. I would guess something more like this would be a little more effective.
Simple hose connection? BataviaJim Plumbing 6 03-25-2010 12:52 PM
Drain hose stuck on washing machine savingedmund Plumbing 3 05-10-2009 10:19 AM
Repairing Electric Central Vacuum Hose jogr Appliances 6 11-11-2008 12:59 PM
garden hose water spillage questions mcvane Landscaping & Lawn Care 10 07-29-2007 12:27 AM
Washing machine drain hose morrisp Plumbing 3 09-01-2006 07:24 PM
