#1 |
Homelite weedeater won't start. Out of ideas.
Brief history: It was my dads and used to run fine except for some problems getting fuel. I found the fuel lines were bad and the little filter end was just rolling around in the tank. So i replaced the line and the bulb fills up no problem.
Now it just wont start at all. I took it all apart last night; exhaust is clear, cleaned a lot of black grime off the cylinder head, took apart the carb and mostly visually inspected it everything looked fine diaphragm still moved, screens were clear, compression seems great. I put fuel directly into the motor and still no start, not even a sputter and die. I pulled the spark plug out, grounded it, and cranked it. Looks like a nice spark appears but I don't know much about plugs. I've tried the 2 stroke mixture gas, I've put un-mixed 87 in the tank, no results. I don't know what else to do and my arm is getting sore! Oh also i don't know where the trims should be set. I've tightened them all the way to the right then went left 2 full turns on each and tried. I heard from somewhere that's a good place to start. Last edited by Jasnall; 05-18-2010 at 02:44 PM. |
#2 |
Compression seems great or compressions is great? Have you put a guage on it?
#3 |
It was a dark and stormy
The spark testers use a 3/16" gap, I think. Having a spark jump under compression requires a higher voltage.
When this happens to me I leave the thing in direct sunlight for a half hour before attempting starting. You could also try one of these extremely volatile starting fluids. Last edited by Yoyizit; 05-19-2010 at 01:52 PM. |
#4 |
No i haven't used a gauge, just going by the difference in feel with the spark plug out and with it back in when pulling the starter. I guess i can get a gauge setup and test it.
I guess the main issue to look at is it doesn't fire even when i put gas directly into the cylinder. |
#5 |
Don't know it all, yet!
If you run it without oil mixed in the gas, the rest of this will be moot.
If there's fuel, spark, and compression, I'm thinking a timing problem.
If it's worth doing, it's worth doing right. If you wouldn't put your name on it, it ain't done right! |
#6 |
Timing! That was my next guess! However I don't know much about adjusting the timing. How do you even do it on these motors?
#7 |
IT'S ALIVEEEEEEEEEEEEEEEEEE!
I put a new spark plug in and about 50 cranks later and some trim fiddling it fired up. I guess I learned that all sparks are not created equal. Like Yoyizit said "Having a spark jump under compression requires a higher voltage." Makes sense to me now. Either way taking it all apart was a good time, and it run really strong now. Thanks to everyone that posted! |
| Display Modes | |
| Ideas Regarding Kitchen Remodeling | Kristal | Kitchen & Bath Remodeling | 2 | 12-20-2009 10:44 AM |
| Garage Ideas? | tripflex | General Discussion | 13 | 12-16-2009 08:06 PM |
| Dining room renovation - looking for ideas | hyunelan2 | Interior Decorating | 1 | 10-10-2009 07:03 AM |
| NEED HELP WITH IDEAS for remodeling a entire home 2100sq ft 2 stories *Many pictures* | BleachCola | Remodeling | 26 | 08-23-2008 07:15 PM |
| Where to start? | loomis1228 | Flooring | 6 | 10-24-2007 03:18 PM |
