Homelite Weed Eater Not Working - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 05-12-2012, 04:43 PM   #1
Homelite weed eater not working
I'm not sure of the exact model of the weed eater, I know it was made in 2006. It has worked perfectly fine for years and all of a sudden it just wont start and theres fuel coming out the muffler when i pull the string to start it. anyone have any ideas? Thanks
rhanson85 is offline   Reply With Quote
Old 05-12-2012, 07:34 PM   #2
Rewards Points: 3,430
Are you sure it's not on full choke.
Canarywood1 is online now   Reply With Quote
Old 05-12-2012, 08:40 PM   #3
A Little Of Everything
Rewards Points: 1,364
First thing you're going to need to do is pull the spark plug, clean it good, and let the cylinder dry out. Maybe replace the plug if you'd like.
Second, you'll need to determine if this is a "first start of the year" problem, or if you've got something messed up in your carburetor. 90% of the problems with these weed eaters is fuel related - everything from too much oil in the mix, to old gas varnished up in the carb, to a tiny speck of dirt plugging an orifice.
After you've dried out the cylinder & cleaned/replaced the plug, try it again. This might have just been a fluke. If not, you'll need to do some carb work.
Let us know what you find.
DrHicks is offline   Reply With Quote
Old 05-12-2012, 08:47 PM   #4
Rewards Points: 13,300
Sure sounds like a stuck float in the carb.
Very common problum.
Old 05-12-2012, 08:50 PM   #5
Unless his is a 4-cycle weed eater (very unlikely) there is no float in the carb. Stuck needle valve? Yeah, that's a possibility.
Old 05-12-2012, 09:44 PM   #6
I have a Homlite 4 stroke. Works pretty good.
Weed eater repairs - carburator cellophane Tools 8 10-19-2011 07:28 PM
Receptacle stopped working lovetobuild Electrical 3 02-11-2011 11:05 AM
Some things not working on a circuit while others are? speedster1 Electrical 7 11-24-2010 07:23 AM
Toro weed eater help! walterbell Landscaping & Lawn Care 0 07-26-2010 08:45 PM
GE fridge evaporator fan change and still not working Trish Appliances 2 03-30-2008 02:47 PM
