Home Irrigation System Not Working - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 04-08-2013, 11:06 AM   #1
Rewards Points: 12
Water to system is on. Control box in garage has power. But the sprinkler heads in all zones throughout the yard fail to raise, and only put out a trickle of water. This happens using the timed setting or manual advance setting at the garage control box. Any thoughts?
needhelpbad is offline   Reply With Quote
Old 04-08-2013, 11:25 AM   #2
Rewards Points: 3,418
Have you programed the zones for duration??
Canarywood1 is offline   Reply With Quote
Old 04-08-2013, 11:38 AM   #3
"You can do anything"-Mom
brockmiera's Avatar
Mine did that last year and it was due to a cracked ball valve at the backflow preventer. Also check to see if you have any other valves along the water path. If you remove the bleeder valve does water come out?
brockmiera is offline   Reply With Quote
Old 04-08-2013, 01:28 PM   #4
Rewards Points: 12
How many zones do you have? One way to check is find your water meter. Turn on your system and watch the meter. If it's spinning like it's going to fly away, you have a leak somewhere. If it's turning slowly, the either the main valve to your system is not fully open or the valve controlling the zone is not opening fully.
Dan
djlandkpl is online now   Reply With Quote
Old 04-08-2013, 07:13 PM   #5
Rewards Points: 12
7 zones DJ, but none of them work. I'll check the water meter, but it would shock me if a leak released so much water pressure that even the first zone doesn't work. I'm guessing that you're right about the main valve. And yes Canary, it's set for duration. Unfortunately Brock, I don't know where the backflow preventer is. The system was installed by the previous owner, and there was no schematic left behind.
Old 04-08-2013, 07:21 PM   #6
Rewards Points: 12
Is this your first year with the system? Are you located in a a cold area? The back flow has valves on it. If your system was blown out last year, odds are one of the valves is partially closed.
Dan
Old 04-08-2013, 08:44 PM   #7
Rewards Points: 12
Not the first year. It worked great for several years. Just went bad last summer. I haven't blown it out lately because the winters have been so mild, and I don't use it much.
Old 04-08-2013, 09:15 PM   #8
Rewards Points: 12
If you have a backflow it should stick out like a sore thumb. I don't think they can be buried in a valve box but not certain. You might have a check valve instead. Follow you water main in the house to where it connects to the irrigation system. Look for a device that's inline on the pipe.
Dan
Old 04-08-2013, 10:53 PM   #9
Rewards Points: 12
OK... Thanks Dan. I'll look tomorrow.
Tags
irrigation system , lawn irrigation , watering lawn
assistance/direction upgrading my home security system dcastillo Electrical 12 10-13-2013 05:13 PM
Irrigation System Supply exiting through House? Ocelaris Landscaping & Lawn Care 2 03-29-2013 11:04 PM
Boiler system not completely filling? jeffro83 HVAC 9 08-31-2012 12:56 PM
home run system using copper insted of pex ogoz23 Plumbing 30 02-14-2012 06:01 PM
What system to purchase for 10,000 sq feet home with seven baths tuckerbergman Plumbing 2 11-04-2011 07:35 AM
