#1 |
Holes in tree
I have a red oak only about two years old and it as two holes in it just under where the branches connect to the trunk. I noticed the holes last summer. I sprayed fruit tree spray on it (recommended by Lowes guy) which is good for just about every bug. I think the holes were created by wood borers.
The tree appears healthy. However, I am wondering if I should some how patch the holes with wood filler or something? I would like to avoid any other insects from crawling in there. Any comments appreciated. Chris |
#2 |
the Musigician
Holes in tree
how big are the holes?
DM
[SIGPIC][/SIGPIC]Click To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. to see some of my original magic tricks and trick boxes! |
#3 |
Holes in tree
One is about 3/4 inch and the other appears be perhaps 3/8 inch.
#4 |
the Musigician
Holes in tree
they make 'tree safe' hole filler. check your local nursery.
DM
#5 |
Holes in tree
Thanks! I'll check it out.
#6 |
the Musigician
Holes in tree
usually the stuff is for large areas when branches get broken off green in storms....
you might want to ask what they would do in your particular case. they may recommend a 'bug killer patch' or something. DM
#7 | |
Don't know it all, yet!
Holes in treeQuote:
If it's worth doing, it's worth doing right. If you wouldn't put your name on it, it ain't done right! |
| Display Modes | |
| foundation weep holes for drainage | shama144 | Building & Construction | 12 | 12-31-2011 12:17 PM |
| Block Foundation w/Hundred Seep Holes? | Jodust11 | Building & Construction | 9 | 04-13-2010 11:41 AM |
| Any arborists out there? Can you help me with the care of this tree? [pics] | perpetualjon | Landscaping & Lawn Care | 8 | 02-27-2009 06:51 PM |
| Vent pipe boots -holes eaten in them | N. Duval | Roofing/Siding | 3 | 02-03-2009 08:52 PM |
| Magnolia tree + septic tank question/problem | Jemo | General Discussion | 5 | 01-18-2007 10:08 AM |
