Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Landscaping & Lawn Care
Old 06-16-2012, 06:44 PM   #1
Hiding steel posts for new privacy fence?
Soon I will replace my existing chain link fence with a 6 foot privacy fence about 270 linear feet. So far the plan is using steel posts, pressure treated rails, top plate, and 6" kickboard (for the big dogs) while using cedar (possible board-on-board) for the slats. I want to do this right the first time so I don't mind spending a little extra for quality.
I'd like to hide the steel posts since they will be facing the yard. One promising option is a rail bracket from OZ Post that has screw points for the rails and for 2x4's ment to surround the post.
This site has a nice install pdf if anyone cares to see more about it. Its the large bracket at the bottom.
http://www.hooverfence.com/catalog/h...e-brackets.htm
My main concern is how secure would the fence be since the rails will not butt up against each other like they would with a standard rail bracket like the Simpson Strong-Tie?
Also, there is the Postmaster Post which is a replacement for the standard steel posts. Some seem to like it, some don't, so I haven't decided yet if I want to try it or go with something more tried and true.
One last bit, I assume a kickboard means there isn't a need for a bottom rail, correct? So just use a kickboard, middle rail, and a pair of top rails connected to top plate be sufficiently sturdy?
Any other advice would be fantastic.
fferd is offline   Reply With Quote
6' wood privacy fence questions snosurfa7 Landscaping & Lawn Care 13 06-01-2012 02:45 AM
Max Fence Height In LA For Pool Privacy ... JasonCA Building & Construction 7 05-09-2011 05:45 PM
Corrugated steel fence? ITSANSS Landscaping & Lawn Care 2 04-13-2011 08:04 AM
Privacy Fence 4x4 Post against Garage? jpearson311 Building & Construction 8 05-19-2010 02:19 PM
Chain Link Fence Privacy? the question General Discussion 2 06-15-2008 11:08 AM
