Hiding Outdoor A/C Units - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 03-06-2010, 08:29 AM   #1
artlover13060's Avatar
Hiding outdoor A/C units
I have three outdoor units, in a row, that I would like to enclose with some sort of fence or outdoor screen. How much clearance do I need to allow between the units and the fence?
artlover13060 is offline   Reply With Quote
Old 03-06-2010, 09:08 AM   #2
Master General ReEngineer
Bondo's Avatar
Rewards Points: 606
Ayuh,... Enough room to get to 'em to work on them when necessary....
Old 03-06-2010, 09:40 AM   #3
Three foot according to most install manuals.
The Following User Says Thank You to Marty S. For This Useful Post:
artlover13060 (03-06-2010)
Old 03-09-2010, 05:50 PM   #4
OP, all you need to do is google up your AC unit model number, and you'll prob get to a PDF document that will show you the clearances they require to achieve maximum efficiency. Sometimes it is more clearance on one side vs another side. Those clearances also account for the need to maintenance it from a particular side.
Just google search the model of your unit and you'll have your answer.
Rhizzlebop is offline   Reply With Quote
Old 03-09-2010, 07:23 PM   #5
diy'er
la15ota's Avatar
We build a box framed around our AC unit and covered it with redwood lattice material.
We can easily slide it out to get to it.
It still allows airflow to the unit....we don't run ours very often so I'm not worried much about not getting max flow.
la15ota is offline   Reply With Quote
Need HVAC solution for basement - 3 zone? or ductless units? skylake HVAC 2 10-06-2009 08:42 PM
Stacked washer & dryer units janralix Plumbing 4 08-06-2009 05:00 PM
5 ton unit or 2 seperate units allenky HVAC 1 06-06-2009 06:35 PM
Need to build enclosure for multiple outside a/c units. firedudesgirl Carpentry 4 03-31-2009 07:10 PM
new 3 ton hvac Payne units. No cool air comes out when fan, compressor,thermostat run runbikeengr HVAC 10 04-10-2007 06:59 PM
