HELP: Standing Water In Front Garden - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 01-11-2013, 09:27 AM   #1
HELP: Standing water in front garden
We live in S. Florida and when we have heavy rain, we experience standing water in the front garden against the exterior wall. It happens in the right side of the picture.
We are planning to add gutters to divert the water from the roof to the side of the house (top of the picture) . But we also want to raise the affected area by 4-6" (the right side of the picture is lower than the center).
1. Will raising the area reduce standing water?
2. If yes, what do I need to do?
Any help will be appreciated.
HELP: Standing water in front garden-img_20130111_101258.jpg
zdace is offline   Reply With Quote
Old 01-11-2013, 09:37 AM   #2
Rewards Points: 13,724
#1 It's never a good idea to have anything that retains water right up againt the foundation.
It can attract subterraian termites, since they need moisture to build there tunnels.
It can also cause issues with the slab.
But to ansewer your question adding the gutters and raising the grade will be a big help to keep water away.
I think I would first add something like #57 stone, a screen cloth then the top soil to aid in drainage.
zdace (01-13-2013)
Old 01-11-2013, 11:44 AM   #3
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,360
Ayuh,.... While raisin' the grade to the right of the picture, may, or may not help,...
Lowerin' the grade on the left side of yer picture, WILL Help, Alot....
The grade is nearly up to the siding, Now...
Old 01-11-2013, 03:19 PM   #4
Rewards Points: 1,512
When raising the ground, do not use gravel. That will leave a porous pocket for water to accumulate in.
Use dense material like fine sand or soil.
The Following User Says Thank You to AllanJ For This Useful Post:
zdace (01-13-2013)
Old 01-12-2013, 07:11 AM   #5
Nest Home Improvement
NestHI's Avatar
Lower the area on the leftside of the photo to give water a path to flow away from your foundation. If this isn't possible (hard to tell with your photo) you can consider installing a drain instead.
NestHI is offline   Reply With Quote
Help! Yellow Hot Water mechetti Plumbing 1 11-01-2012 08:57 PM
Leaking water line needs new water regulator? huynh Plumbing 16 11-04-2010 11:32 AM
water pouring into basement from around water supply line matty8199 Building & Construction 29 12-29-2009 05:07 PM
(Water Heater MYSTERY) Hot water out from dead tank with cold water in it? Inayity Plumbing 6 07-14-2008 08:36 PM
Is 1/2 Pex more restrictive than 1/2 copper? twilightcall Plumbing 19 06-24-2008 07:32 AM
