Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Landscaping & Lawn Care
Old 01-17-2013, 06:17 PM   #1
Help solve yard drainage issue
I am having some pretty serious drainage problems. The pics below are just of the back yard from right to left. There are issues on the sides on the house too. I dont know where to start? Regrade the whole back yard? dry well somewhere? The real issue is there isnt really any slope to work with to get the water out to the street. Any suggestions? Do I have a high water table?
More info: the back yard is wet all the time. I have yet to see it dry (been living in the house about 3 months). Even the parts where the elevation seems higher is soggy too?
The pics below are after about a 10 day in a row rain so this is the worst ive seen it.
Help solve yard drainage issue-img_1357.jpg   Help solve yard drainage issue-img_1358.jpg   Help solve yard drainage issue-img_1359.jpg   Help solve yard drainage issue-img_1361.jpg
jabrock1 is offline   Reply With Quote
Old 01-17-2013, 07:31 PM   #2
Regrade the land so the low point is at the edge or the corner. Dig a dry well there and install a sump pump in it to empty it out if it fills up.
The disadvantages of crab apple trees. In summer, the apples are too sour to pick and eat. In winter the birds come and leave dropping all over the place.
Old 01-17-2013, 11:51 PM   #3
Doityesterday
Send a message via Yahoo to papachuck
Hello, First if I may ask were are you located? And what kind of soil do you have? if your water table is that high and wont drain A sump pump may never shut off. and you may not be able to pump to A ditch or street per codes .the way it looks your surrounded by houses and such.looks like grass rot the only thing that looks like it is doing well is the shrubs. witch with A raised bed it would.it is also in some areas to regrade A parcel of land to drain on other lands illegal in some states. do you know if there is A drainage ditch that the city or town would let you hook into?there is ways to fix this but there is also sometimes rules.
papachuck is offline   Reply With Quote
Old 01-22-2013, 10:08 AM   #4
I live in Alabama. The snow you see on the ground is very rare haha. I am unsure of the soil type but I figure it contains alot of clay. Also I am at the bottom part of a hill, surrounded by houses. I believe a regrade would be best but it seems that it will take alot of dirt to raise the elevation and slope it to the street. Any suggestion on how to regrade the land? The problem is that water doesn't really drain on the sides of the house either so I don't know how I would regrade to get the water to the street. I'm not sure if I can tap into the sewer. Is that an expensive thing to do? Could I do it or would a professional need to do the work?
Thanks for the replys thus far!
Old 01-22-2013, 10:51 AM   #5
Newbie Bill
Can you post some more photos of the areas beside your home?
Do you have any eavestroghing to move the water from your roof away from house?
Asking questions is free, so keep them coming.
Bill
A DIY Noob that knows just enough to be dangerous.
drtbk4ever is offline   Reply With Quote
Old 01-22-2013, 12:42 PM   #6
I will post some pictures up when I get off work. And yes I do have gutters.
Old 01-22-2013, 01:57 PM   #7
There not going to let you hook up directly to the storm drains. That's been againt the law for many years.
Old 01-22-2013, 02:08 PM   #8
Master General ReEngineer
Bondo's Avatar
Ayuh,.... Insteada Raisin' the whole thing,...
Cut pitched swales to direct the water away, 'n outa the yard...
Old 01-22-2013, 11:19 PM   #9
looks like the gate might be a low spot. rent one of these http://www.engineersupply.com/CST-be...e-RL25HCK.aspx
and map out your back yard. get a bunch of http://www.homedepot.com/h_d1/N-25ec...1#.UP9kXie5PUk, yes there are better deals out there for these, and mark the low spots or the high spots.
redman88 is offline   Reply With Quote
Old 01-22-2013, 11:46 PM   #10
The gate is definitely a low spot. The problem is I don't have anywhere to drain the water. It's probably close to 100 feet to the street with almost no slope to work with.
I will get pictures of the side of the house soon btw.
Old 01-22-2013, 11:52 PM   #11
Could you elaborate a little more on this?
Old 01-23-2013, 12:06 AM   #12
http://www.google.com/search?q=dry+r...hrome&ie=UTF-8
just had this idea, put one in under the gate, and along the fence line althe way around the house.
Old 01-23-2013, 12:11 AM   #13
I'm unsure if this will make sense but here it goes.
For this question just say I have a level grade on the side of the house from the back side of the house to the street. Also the land is even with the street. If I was to dig a drainage ditch that sloped 2 feet from the back of the house to the street. Meaning the drainage ditch would end up 2 feet below street level. Would this do anything to help? I know water would be puddling toward the street, but would it overflow onto the street and then to the sewer?
Old 01-23-2013, 09:37 AM   #14
Bondo's Avatar
Ayuh,.... Unless you can set up a level, to See how much drop you have, this is all just Guessin'....
If you actually have No pitch to work with, the only answer left is to install a drywell...
Then either pitch the surroundin' ground to it, or use sub-grade drainage pipin'...
The 1 Given, that can't be changed is,....
Water flows Downhill....
yard drainage rockportbill420 Landscaping & Lawn Care 1 04-10-2011 09:20 AM
Black or white yard drainage pipes spiragui Landscaping & Lawn Care 2 03-09-2011 03:44 PM
Drainage issue macook01 Landscaping & Lawn Care 3 03-03-2011 06:01 PM
Backyard Drainage Issue bobssurfin Landscaping & Lawn Care 16 09-30-2009 03:18 PM
Drainage issue from heating system and washing machine susandlynn Plumbing 1 11-17-2007 03:28 PM
