Help Retaining Wall 6x6 Timbers, Out Of Plumb - Landscaping & Lawn Care - Page 2 - DIY Chatroom Home Improvement Forum
Old 04-23-2013, 10:02 AM   #16
Originally Posted by red92s View Post
How high is this wall going to be? Just tall enough to hold back that little slope where you have removed sod (~2-3 courses above grade)?
Also, I don't see how the current position of your toe drain will allow you to run it to daylight. It is below the grade of the sidewalk all around. You'd likely need to install it on TOP of the material that is backfilled behind the bottom course.
The highest part of the wall is going to be slightly higher than the top step in the background about 3ft, i'm going to have my wall make take a 90degree turn into the hill, and i'll be adding a mulch and flower bed where the grass is now.
The drain pipe will not be placed where it is in the photo, it's going to go above the first coarse.
carneyxii is offline   Reply With Quote
Old 04-25-2013, 10:43 AM   #17
how does this sound 2 A sub base (modified) for my base and 3/4" quarry stone to back fill.
good?
Old 04-25-2013, 10:48 AM   #18
Rewards Points: 165
good?
Should be. The 2A base might have some big rocks that make it tough to get the top perfectly level. Just pluck those out and fill in with some of the finer material when you are compacting the top.
Are you just using a hand tamper? I doubt a plate compactor would even fit in a trench that narrow?
red92s is offline   Reply With Quote
Old 04-25-2013, 11:49 AM   #19
Is there another stone you suggest. I live just outside of Philadelphia if there is a place that delivers the right stuff I'd love to know.
I looked at www.mulch-it.com to find the 2a base
I have an 8x8 tamp
Old 04-25-2013, 11:55 AM   #20
Rewards Points: 165
I have an 8x8 tamp
It's very regional what things are called. Looks like essentially a road base material, which should be good. It should compact nice and tight, especially if you wet it lightly during tamping. Only tamp ~2" at a time. On your top layer you can pluck out the big stones to get a nice flat surface. Wouldn't be a terrible idea to use the same material BEHIND the first course as backfill as well, and then have your drain line on top of that.
Tags
retaining wall , timber
6X6 Timber Retaining Wall Additions Tom5151 Landscaping & Lawn Care 2 02-22-2012 10:46 AM
Retaining Wall and Muddy Yard rjschwar Landscaping & Lawn Care 10 02-24-2010 12:55 PM
about to do my first retaining wall wombosi Landscaping & Lawn Care 2 06-08-2009 01:39 PM
Drainage Tile and Retaining Wall nabz Landscaping & Lawn Care 3 05-25-2009 01:22 PM
Low Retaining Wall cibula11 Landscaping & Lawn Care 3 07-29-2007 12:02 AM
