Help! Need Way To Locate Low Voltage Light Cables - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 12-30-2007, 11:40 AM   #1
Johnboy555's Avatar
Exclamation
Help! Need way to locate low voltage light cables
Hey!
I'm a handyman and sometimes I need a way to find breaks in low voltage light cables. Usually they're less than 6 inches underground, but sometimes the landscapers will cut through them and then it becomes my problem.
I've seen lots of cable locators, but they range from $400 +. That's a little high for something that I would use only about 3 times a year. I'm looking for something that injects a signal into the wire and then has a receiver that can locate the wires ( and breaks). Not a lot to ask for, but all I've seen are ones that are meant for house voltage, and such.
Has ANYONE got an idea where I can even look for something to accomplish what I need for under $200???
Thanks!
Johnboy555 is offline   Reply With Quote
Old 01-01-2008, 06:37 PM   #2
Insert catchy title here
AppleMac*Fit's Avatar
Bury the wires to 18" then you don't have to worry about cuts anymore. It's a lot cheaper than a tic tracer.
If you don't want to do that, here's your best option...
You shut off power to the system, and it will send a signal through the wires that you can trace to the point of the break.
Greenlee Buried Line Locator 508S $286.00
http://www.grainger.com/Grainger/items/1UG79
AppleMac*Fit is offline   Reply With Quote
Old 01-02-2008, 02:39 AM   #3
Johnboy555's Avatar
Thanks Apple-Mac This is closer to what I had in mind. I will look into this.
Low Voltage Light Switches...40 year old house derekspudich Electrical 28 08-22-2011 12:34 AM
Trying to replace wall mounted light fixture jtm2300 Electrical 4 08-03-2007 09:44 PM
Low voltage Light Rze Electrical 4 04-21-2007 11:38 AM
Hot Light Outlets Materials Guru Electrical 5 07-31-2006 07:11 PM
Replacing light killed downstream outlets, totally stuck amissner Electrical 5 07-13-2006 06:02 AM
