Help Flagstone Walkway - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 05-19-2009, 11:14 AM   #1
help flagstone walkway
My husband has installed a flagstone walkway in our front yard but we are having a problem. The screening is washing out at a very fast pace. We are having trouble replacing fast enough and I am not sure what to do to fix it. He continues to say we will just to constantly replace it but that sounds crazy to me. What is the best way to keep the flagstone in place? Any help would be appreciated.
cairokt is offline   Reply With Quote
Old 05-20-2009, 06:13 AM   #2
ccarlisle's Avatar
Best is to either give us some pictures, or describe in detail what you did, what materials you used and what procedure you followed to do that job...we can't see.
Are you talking about the screening underneath the stones or the grout around them, or both? did you compact?
“The average American woman is about 25 pounds heavier than she was in 1960...Recognizing obesity as a disease will help change the way the medical community tackles this complex issue that affects approximately 1 in 3 Americans,”
ccarlisle is offline   Reply With Quote
Old 05-20-2009, 08:42 AM   #3
Not an expert, but if the grout is washing away it could be from lack of edging to hold it in place. Polymeric sand will harden somewhat and stay in place if you don't mind changing the look. If the base material is doing it, it could also be from lack of a hard edging as well. There could be some lawn drainage issues going on. A buried "french drain" or channel away (filled with rock and covered with fabric) might stop the damage from water. Mabye dig out a post hole and fill with rock(?). I don't know, it may require removing completely and setting higher.
Stillwerkin is offline   Reply With Quote
Walkway near big trees--how to deal with roots! jetstover Landscaping & Lawn Care 16 07-26-2011 06:21 PM
Underwater Walkway k.kuenn Landscaping & Lawn Care 2 03-09-2009 07:45 PM
Concrete Walkway with Exposed Aggregate BTn5qsc2zB93ztGN9vJP Landscaping & Lawn Care 4 08-22-2008 07:49 AM
Need help with a flagstone walkway Waleye Landscaping & Lawn Care 4 02-26-2008 09:06 AM
