Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Landscaping & Lawn Care
Old 01-28-2013, 03:51 PM   #1
Have to love the neigbours shed..
Moved into a new build with, ok skip the descriptives, a 'large shed' 6" from the property line. I understand in my neck of Ontario sheds are supposed to be 18" from the back property line.
It also has an evestrough around it that drains from the back onto our lot. It has probably been there for 10-20 years and is the source of lots of nice metal-fabrication sounds and smells.
Fence will be going up soon... albeit neirly flush with the back of this SR&ED (probably post on my side would be just about touching the gutter). How much success would there be in having the:
1) Shed 'moved'! ( Probably a bit extreme - probably saved by mothering rules)
2) Drain pipe 'repositioned' - are you allowed to drain direct like this??
mikegina is offline   Reply With Quote
Old 01-28-2013, 04:12 PM   #2
All those questions would be better ansewed by your local zoning and building dept.
If it's been there that long it may come under eminient doman laws or something like that.
Meaning if someone is allow to use the property as there own for a certin lenght of time you loose the rights to the property.
http://en.wikipedia.org/wiki/Eminent_domain
Old 01-28-2013, 04:23 PM   #3
Become friends with them and ask him to move the drain pipe. Nothing worse than p!$$ing off your neighbors with code inspectors.
pwgsx is offline   Reply With Quote
Old 01-29-2013, 11:48 PM   #4
Originally Posted by pwgsx View Post
Become friends with them and ask him to move the drain pipe. Nothing worse than whizzing off your neighbors with code inspectors.
You are right you should become friends with the neighbors and then slowly ask them for that i bet they won`t say no.
paulsmith544 is offline   Reply With Quote
Moving an 8x10 wooden shed 100 miles; how? (Video of shed inside) snowfall General Discussion 32 10-23-2012 09:54 PM
Proper transition between shed roof and shingled roof? aribert Roofing 9 04-12-2012 04:17 PM
Zoning issue with planned shed Ler0y Jenkins General Discussion 15 02-01-2012 01:41 PM
wiring a detached shed for AC power *and* generator backhaul wrooster Electrical 19 05-28-2010 12:59 PM
