Hanging Baskets - Brick Wall - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 03-18-2014, 12:20 PM   #1
I wish to hang baskets from a brick wall. The baskets will be filled with plants and some dirt/soil.
What is the best method to hang the baskets from the wall?
Would you recommend using Nails (like Masonry Nails of some kind)?
Would recommend drilling into the Brick or into the Mortar?
Thanks !
laawaaris is offline   Reply With Quote
Old 03-18-2014, 01:03 PM   #2
iminaquagmire's Avatar
Rewards Points: 338
Going to be hard to do without drilling the mortar/brick. Tapcon screws will certainly work as will many other concrete anchors. If you want it to be removable (as in not permanent) use a tapcon or plastic anchor/screw rather than a hammer set nail type. I would not try to put tapcons into the brick itself as the treads can strip out the brick or crack it. Better to go into the mortar. If using the the plastic anchors with screws, drilling into the brick is fine.
iminaquagmire is offline   Reply With Quote
20 year old Brick Wall Repair Bobrobert General DIY Discussions 15 11-22-2011 03:07 PM
Capping a brick parapet wall jrschenck Roofing/Siding 2 08-21-2011 11:22 AM
Attaching Willow Screen to brick wall tripled Landscaping & Lawn Care 5 08-12-2011 06:46 AM
how to tell if a brick wall is load bearing eskowitz Building & Construction 10 08-01-2010 10:00 PM
New opening in a brick veneer wall - installing new brick ties? GrantJohnson Building & Construction 3 01-28-2009 10:17 AM
