Had Soil Tested...need To Add .7 Pds Of Nitrogen Per 1,000sqft - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 04-06-2010, 08:38 PM   #1
had soil tested...need to add .7 pds of nitrogen per 1,000sqft
So I got my soil test results back from Texas A&M and they state all I need to do is add .7 pds per 1,000 sq ft of nitrogen to the lawn, nothing else is required. I normally use Lesco weed and feed 18-0-9 from HD, how much should I use to not add too much to the lawn?
Thanks in advance.
jongordo8 is offline   Reply With Quote
Old 04-08-2010, 06:40 PM   #2
GardenConcepts's Avatar
Rewards Points: 150
18-0-9 is 18% Nitrogen. Take the weight of the bag of fertilizer x 18% and the result is how many pounds of Nitrogen are in the bag. You'll need a good spreader with calibration instructions to figure out what setting to use to get .7 lbs. per 1000 sf.
So if you have a 25lb. bag, you'll have 4.5 lbs of Nitrogen in the bag. That should cover 6500 square feet.
GardenConcepts is offline   Reply With Quote
Soil waste pipe through pitched roof DIYifposs Roofing/Siding 1 11-21-2009 02:34 AM
difference between pH, fertilizer and nitrogen? windowguy Landscaping & Lawn Care 5 07-29-2009 10:19 AM
soil grading for basement moisture jpenns Landscaping & Lawn Care 4 07-15-2009 09:44 PM
Question about soil amendment application methods joeyboy Landscaping & Lawn Care 1 04-26-2008 08:29 PM
Question regarding soil makeup (will my soil amendment idea work?) joeyboy Landscaping & Lawn Care 5 06-30-2007 10:24 PM
