Gutter Fixed...Hopefully - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 06-10-2010, 09:30 AM   #1
gmhammes's Avatar
Gutter fixed...Hopefully
So i have had a leaky seam in my gutter for some time now however since the deck is nearing completion i prefer it no leak onto my new Deck!
So on the ladder i went. I drilled out the old broken rivets, cleaned the joint thoroughly, applied gutter silicone on the seam, and shot 4 new rivots into it. One more swipe of silicone and it should be good.
Not that it's a huge DIY project but if it needs fixed then it's a project to me!
gmhammes is offline   Reply With Quote
Old 06-10-2010, 04:18 PM   #2
Rewards Points: 1,088
What "gutter silicone" did you use?
handy man88 is offline   Reply With Quote
Old 06-10-2010, 06:27 PM   #3
gmhammes's Avatar
OSI gutter sealer. "box store" stuff.
Old 06-10-2010, 06:34 PM   #4
gutters
That should do it, as long as it was cleaned well for the silicone to stick. I use the OSI regular white caulk on gutters, because it will seal through 5" of water, if the gutter inside is clean. I also like Geocel 2320, it is one of the only sealants I've found made specifically for gutters. I seal alot of gutters everyday, 15 yr. gutter guy. Hope your leak is fixed. God Bless.
getrdone is offline   Reply With Quote
Old 06-11-2010, 07:55 AM   #5
gmhammes's Avatar
thanx. yep, we'll see next rain.
Old 06-11-2010, 11:32 AM   #6
Newbie Bill
Rewards Points: 520
What would be the best thing to use to clean the gutters before applying the silicone?
Bill
A DIY Noob that knows just enough to be dangerous.
drtbk4ever is online now   Reply With Quote
Old 06-11-2010, 01:35 PM   #7
gmhammes's Avatar
i used just an all purpose cleaner, then scuffed it with some steel wool, then wiped it clean with some alcohol. Of course let it dry completely before putting the silicone on.
Old 06-11-2010, 05:20 PM   #8
Excellent cleaning job, very thorough! That would work every time. If not you have to use a screw driver to scrape the old caulking out completly, or a wire wheel on the end of a cordless drill works good, then scrub it clean with a rag. Reapply new caulk.
Old 06-11-2010, 05:25 PM   #9
Newbie Bill
Rewards Points: 520
Thanks guys, I have a repair to do and I may as well do it right the first time.
Bill
Old 06-11-2010, 07:08 PM   #10
http://www.amazon.com/Hyde-Tools-029...6301293&sr=8-1
Old 06-13-2010, 11:04 AM   #11
Reseal Mitre
Originally Posted by handy man88 View Post
If your resealing an existing Mitre, I like to try to completly remove all the old caulking first, sometimes you get lucky and can pull it all out with one stong grab on a corner of the caulk, if not I scrape it loose with a flat head screwdriver and pull it as I go. Once all the caulk or as much as possible is gone simply scrub it hard with a rag, making sure there is no " MOLD" left in there, that is what prevents the new caulking from sticking, the mold. Once the gutter is clean of all mold and is bone dry, re-apply new caulk generously, my rule of thumb is 3/4 of a tube of caulk per mitre, if it is a standard 6" gutter. I like to use a Ferrulle pounded flat on the end to create a " spoon" effect and use this tool to evenly spread the caulk inside the mitre, and "press the caulk into the gaps in the seams, then cover those gaps generously. Hope this helped. Good Luck.
Squirrels chewing the gutter guards... gshock Roofing/Siding 3 06-29-2016 12:24 PM
Rain gets underneath gutter Heimwerker Roofing/Siding 8 12-28-2011 12:59 AM
Gutter leaks after roof replacement Jim F Roofing/Siding 6 04-16-2010 08:42 PM
Rain gutter slopes the wrong way ovahimba Roofing/Siding 2 12-20-2009 03:56 PM
"Frozen" Gutter Leak cougar01 Roofing/Siding 19 02-10-2009 06:07 AM
