Gutter Drainage - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 08-22-2010, 05:37 PM   #1
Question
gutter drainage
Hello!
What a wonderful forum, I wish I had found this sooner! Anyway on to business. I want to reroute a gutter that drained onto out driveway (and caused it to crack and sink). I'm planing running a pipe under the driveway and having it drain out at the side of the house. I'm just wondering how it should drain at the end. I was just thinking of digging some trenches and letting it drain off into the brush. Should I put a dry well? I live in the midwest btw. Thanks!
BryanDIY is offline   Reply With Quote
Old 08-22-2010, 06:29 PM   #2
Don't know it all, yet!
I see that you have already bought the pipe, but why did you not use the slotted pipe and let it drain into the soil under the lawn?
I would not end the pipe right in front of that pine tree. You have a risk of getting the ground soft after a good rain and the tree coming down. Is that a swale, ditch or creek just beyond? I would run it to there and not take a chance on creating a soggy spot in the yard.
Looks like you used a sodcutter to clean the path. Good job!
If it's worth doing, it's worth doing right. If you wouldn't put your name on it, it ain't done right!
downunder is offline   Reply With Quote
Old 08-22-2010, 10:31 PM   #3
Slotted pipe...I didn't think of that. I suppose I could drill some holes on the bottom. That tree will be coming down. Yes, that wooded area is lower than the yard.
Old 08-22-2010, 10:53 PM   #4
Tom Struble's Avatar
Rewards Points: 2,002
why would he use slotted pipe to route roof runoff?
Tom Struble is offline   Reply With Quote
Gutter installation questions Homerepairguy Roofing/Siding 7 03-15-2012 10:22 AM
Gutter Drainage secutanudu Landscaping & Lawn Care 5 03-26-2010 08:16 AM
The IPGC Drainage Pipe agster97 Landscaping & Lawn Care 0 07-09-2009 12:05 AM
Drainage & Sump Pump Advice FredAt Building & Construction 3 06-11-2009 09:14 AM
Drainage Tile and Retaining Wall nabz Landscaping & Lawn Care 3 05-25-2009 01:22 PM
