Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Landscaping & Lawn Care
Old 09-10-2009, 03:16 PM   #1
Default Growing plants on top of a patio wall.
I'm trying to figure a way to grow a plant with long foliage on top of my patio wall. The wall is about 4 1/2 feet tall and is about 1/2 ' wide. I'm thinking of building a rectangular box to hold the soil, but I'm not sure how to implement the draining. On rainy days, I'm sure this box over fill.
Any suggestions?
suncowiam is offline   Reply With Quote
Old 09-10-2009, 08:34 PM   #2
Default mini French-style drain and drainage pipe
Well, you would have to line the box with something water-proof - like a shower pan liner. Then, I would fill the bottom with at least an inch of gravel or small stone/pebbles and arrange a slant toward a good area to put a drain (where you can't see it coming out). Kind of like a shower drain - sloped to where you want it to drain. Then drill a 1" inch hole on an angle in the box and insert a 1" piece of PVC through to capture and allow the water to drain out - cover the end inside the box with wire mesh, as in for a faucet to prevent stones from going through it. Seal the areas where the PVC goes through with silicone to prevent leakage. You may be able to use copper instead of PVC as it would look nicer if you can see it coming out.
Seems complicated, I know... I hope there is an easier solution! Good luck!
missfixer is offline   Reply With Quote
Old 09-10-2009, 08:53 PM   #3
yeah, i was thinking of something similar. just didn't want to put so much effort on the draining. thanks for you suggestion.
Old 09-13-2009, 10:25 AM   #4
Old fart still learning!
Any chance you could shoot us a photo?
If it's worth doing, it's worth doing right. If you wouldn't put your name on it, it ain't done right!
downunder is offline   Reply With Quote
Old 09-15-2009, 11:54 PM   #5
I took a video:
http://www.youtube.com/watch?v=67bu4uc7OhM
Let me know. Thanks
Old 09-16-2009, 03:11 PM   #6
Fixer-'til-broker
DIYtestdummy's Avatar
Get a few ceadar or redwood (any rot-resistant wood) planks. Fence planks will do. Build boxes however big/elaborate you wish. Drill 1/8-1/4" holes near the bottom. Put gravel in the bottom, fill with soil, plant, done. Don't make it more complicated than it needs to be.
"Waitaminute, don't we have 2 rakes?"
http://www.youtube.com/watch?v=EJxpv...eature=related
DIYtestdummy is offline   Reply With Quote
Old 09-16-2009, 03:26 PM   #7
I could give this a try for one season and see how it goes.
Old 09-16-2009, 03:30 PM   #8
concretemasonry's Avatar
Go to HD and look at the plastic "tubs" available with trays for excess water. They come in several colors, are about 7"-8" wide and 18", 24" & 30" lengths.
Build a wood box (your choice of materials) and just put in a few 5/6 treated supports inset in the bottom. The box will be over width, but if long anr one of several it makes a nice cap for the wall.
Anchor the boxes to the top of the wall and put in the the size tubs and trays you have decided to buy.
I use these as on slab planters on the patio and also hung on the balcony of my townhouse. - Not high-tech, but it works and the trays hold extra moisture to eliminate frequent watering, but do allow an overflow.
Dick
concretemasonry is offline   Reply With Quote
Old 09-16-2009, 03:33 PM   #9
Anchor the boxes to the top of the wall and put in the the size tubs you have decided to but.
Dick
Thank you for your suggestions.
Old 11-07-2009, 07:50 AM   #10
diytestdummy; Thanx for the laugh, I needed that! God Bless y'all!
Lali is offline   Reply With Quote
More On This Topic
We are going to talk a little bit about the toilet flange here and this is where your toilet will sit. This is a 3 inch toilet flange and it ties down into our main 3 inch AVS sewer line and again we have that 1/8 inch fall per foot so that the solids... Read More »
Irrigation systems comprise a number of elements, including valves. A shut-off valve, generally located as close to the irrigation system's water source as possible, lets you manually turn off the water to make adjustment to your system. Control valves... Read More »
Plastic grocery bags came on the scene in 1955. Today, four of every five grocery bags are plastic, creating the need for recycling programs at the supermarkets as well as other uses for the bags at home. The following list gives you several ways to use... Read More »
We have a second bathtub that we're going to be treating a little bit differently so we have two that we're going to be working with. The drainage system that we're going to use in this one is going to be from a PVC pipe. This is a thin walled what is... Read More »
You can beautify the grounds of your home by building a pond and reveling in the serenity it provides. Just follow these steps. Read More »
Do I need a wall? gruntman Landscaping & Lawn Care 11 09-30-2009 05:30 PM
installing patio door when exterior wall out of plumb charliebrown314 Building & Construction 0 07-06-2009 03:01 PM
retaining wall - temporary soil retention while building arta Landscaping & Lawn Care 0 05-05-2009 11:33 PM
Breaking up a long/continuous wall tigereye Interior Decorating 4 03-08-2009 05:43 PM
Loads on a partition wall acyate Building & Construction 8 03-01-2009 01:02 AM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
