In-ground Sprinkler System Doesn't Work - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 07-07-2014, 10:55 PM   #1
We've just moved into a place which has a Lawn Genie in-ground sprinkler system installed. I've managed to obtain the manual online, but it seems to be all about the control system (mounted on a wall inside). There's not a thing in it about the outdoor setup.
I've attached a couple of pictures of the outdoor setup. I have no idea what it is, what it does, or what I should do with it. But as things stand at the moment, when I use the control system to turn the sprinklers on...nothing happens. But it has been demonstrated to my wife, so we know it does work. The only question is why it isn't. On one of the posts sticking out of the ground there's a switch which can be set to 'On' or off (shown with a red arrow in the image). As far as I can tell, it makes no difference at all.
Any help at all will be gratefully received.
In-ground Sprinkler System Doesn't Work-one.jpg   In-ground Sprinkler System Doesn't Work-two.jpg
Budfudder is offline   Reply With Quote
Old 07-07-2014, 10:59 PM   #2
Remodel and New Build GC
MTN REMODEL LLC's Avatar
Rewards Points: 3,344
WAG...... See if your water system valve to your sprinkler pipe (control manifold is open)... often teurned off in vacant/leaking sprikler systems.
MTN REMODEL LLC is online now   Reply With Quote
Old 07-07-2014, 11:26 PM   #3
JOATMON
ddawg16's Avatar
Rewards Points: 1,956
Most logical first step.....you can confirm the valves 'sort of' work by turning that knob on top.
Assuming you get water......start checking connections...and check the fuse on the controller.
Those use 24Vac....there is a fuse for the supply. If there is a short somewhere...the fuse blows but the controller is still on.
Old 07-08-2014, 10:14 AM   #4
Thanks a lot for your reply. I'm sorry...but you'll have to be a bit clearer. I really know nothing.
What is 'WAG'?
Where do I see my water system valve to my sprinkler pipe? I think I understand that you're saying the water to the sprinkler pipe might be turned off (the equivalent of pulling the fuse), so that nothing I do with the sprinkler system will make any difference at all. If that's the case, where will I find whatever I need to find to check that and turn it back on (if it's off)?
Old 07-08-2014, 10:19 AM   #5
Thanks for taking the time to reply - but as I said to the previous reply, I'm really clueless. I need you to be simpler. Think as if you were explaining it to a semi-intelligent ten year old.
Okay, eight year old.
If I turn the knob on top (which way? Clockwise or anti?) what should happen that will confirm the valves 'sort of' work?
What connections should I check? Do you mean the physical wire connections between the whatever-they-ares sticking out of the ground (okay, maybe seven year old)?
Where is the fuse on the controller? For that matter, where is the controller? Wait - even as I typed that I think I realised - the controller is the control panel inside the house? I believe I've even noticed a fuse on that.
Old 07-08-2014, 10:33 AM   #6
What is 'WAG'?
Buddfudder.... Great Name
WAG= Wild Ass Guess
You understood my comments exactly..... finding your water supply lines is basically pokeing around and getting to know your system.
Some tips:
Sprinkler systems are often put in in a white PVC plastic pipe . They obviously have to have a water supply, which often is picked up at either an outside water meter, or where your line enters the house, or at a outdoor water spigot and there will be a backflow preventer and a valve, could be metal or plastic.... sometimes those water supply valves are at the normally green plastic boxes used to decoratively cover the sprinkler manifolds and wiring.
Good luck
Old 07-08-2014, 07:49 PM   #7
Rewards Points: 2,638
Then you need to do some homework, or call a landscape company and pay them to get it running.
You have sprinkler heads in your yard -- they pop up and spray when water reaches them. They are grouped in zones --- your house can't supply enough water for all the sprinkler heads at once, so there is a solenoid valve for every 4-8 sprinkler heads. The solenoid valves can be operated manually.
So first you need to know you are getting water to the solenoids. Nobody on the internet is going to be able to find the shut-off on your house-- you will need to find it.
Second, you need to manually open the sprinkler solenoid valve. How? Most you turn the solenoid. Go to the Lawn Genie web site try to find the valve you have. Once you think you know the valve type --- look the that model number is molded into your valves. When you know the model number, should be pretty easy to find operating manuals/how to fix/replace --- see also You-Tube.
Third, if the valve works manually, does it work electrically? You have the manual for the controller, so you should be able to run a zone. A voltage meter will confirm if power is getting to the solenoid.
From the little I know, seems like pretty much all manufacturers make cheap solenoids with no strain reliefs on the wires, so the wires can break easily, particularly right at the solenoid where you grab it to turn it manually. Also, any connection with a wire nut can corrode and lose contact (they sell good wire nuts for sprinklers that are weather rated, but many people decide to save a few cents)
Lawn Genie Manuals : https://www.lawngeniestore.com/Comer...oduct_manuals/
SPS-1 is offline   Reply With Quote
Old 07-10-2014, 06:09 PM   #8
Originally Posted by SPS-1 View Post
Then you need to do some homework...[/URL]
That's what I'm doing here...homework. Trying to learn.
Old 09-21-2016, 11:05 PM   #9
Trucker Geek
Rewards Points: 54
Re: In-ground Sprinkler System Doesn't Work
I had a similar problem when I first moved in. Turns out a random, unlabeled light switch in the garage controls power to the well pump that feeds the sprinklers. So look for silliness like that, or perhaps ask the previous owners?
Stian is offline   Reply With Quote
Old 09-23-2016, 11:14 AM   #10
Rewards Points: 70
My relative has one of these systems and we are both just as curious about it as you are! We spent an entire day trying to troubleshoot it with no luck.
Following this post!
ThatTreeGuy is offline   Reply With Quote
Old 09-23-2016, 04:48 PM   #11
Oso954's Avatar
Rewards Points: 1,300
Here is an article on testing/fixing sprinkler valves.
http://www.irrigationtutorials.com/h...hat-wont-open/
Oso954 is online now   Reply With Quote
50 Amps for a garage help IcyShadowz Electrical 48 05-31-2012 10:58 PM
Sprinkler system Coleen Landscaping & Lawn Care 2 08-14-2011 06:47 PM
Duct work question vs new ac system mdusenbery HVAC 4 05-31-2011 02:32 PM
240 volt load/appliance and ground vs neutral kgize Electrical 7 04-22-2010 11:40 PM
Sprinkler System - Installing Valve Box tazmajazz Plumbing 3 01-06-2009 09:14 AM
