Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Landscaping & Lawn Care
Old 04-29-2010, 02:59 PM   #1
Ground preparation for laying pavers
Could tamped down pea gravel be used for the underlayment before putting sand in to lay 16" pavers?
barryrk is offline   Reply With Quote
Old 05-01-2010, 08:47 PM   #2
remodeling pro
I do not know what the "official" guidance is on this, but my opinion is that pee gravel would not make a very stable base. Since it is basically round, the pieces can not interlock, so no matter how much you tamp it, it just keeps rolling around like a bed of ball bearings.
Be interested to see what the real landscape guys think.
troubleseeker is offline   Reply With Quote
Old 05-02-2010, 08:28 AM   #3
I agree. I have never used or heard of anyone using pea stone for this purpose.
The drainage would be excellent. However in an effort to compact it the pea stone would squish out the sides. Forever moving.
Any type of sand bed would end up filtering down into the pea stone.
Thus the pavers would have to be laid directly on the stone.
Stick around maybe someone has used it and can elaborate.
Bushman is offline   Reply With Quote
Old 05-02-2010, 10:08 AM   #4
Xtreme DIY'r
I used pea stone under the walkway to my basement & to my pool area -4.5" pavers
The basement walkway is fine, I drive my truck across the pool walkway
So that has moved due to grading & weight of truck w/lots of weight (wood, more pvaers for another patio)
Once I'm finished w/construction & grading is corrected I'll redo the walkway
I did not vibrate compact either walkway - small
Not sure how it will work on a larger area w/sand & virbration
Pea stone was from an area that former owners filled
Old 05-02-2010, 04:16 PM   #5
GardenConcepts's Avatar
the compaction is more of an issue with different size/mix stone, although angular will compact better than round. You might try adding some screenings/fines to the pea gravel to get better compaction.
Chris
GardenConcepts is offline   Reply With Quote
Old 05-03-2010, 08:56 PM   #6
I just started prepping for a patio with 16 x 16 pavers this weekend. I framed it out and layed crushed gravel, hand tamped it and will be allowing it to settle until I put the sand and pavers on next weekend. The crushed gravel has already become extremely hard and looks to be a great surface to build on. I will let you know how the finished product looks. Just my two cents... crushed gravel seems to be a suitable surface.
Hoopscoach is offline   Reply With Quote
Old 05-03-2010, 09:45 PM   #7
concretemasonry's Avatar
If you ever build someting with real loads, you will never use "pea stone" because it does not compact unless you have something mixed in with it. For things like driveways, streets, airport taxiways (747 caliber) or harbor facilities (100 ton straddle loaders), the only thing used is a road base with a 1" sand cushion. This is for the small interlocking pavers since the larger (over 9" maximum dimension) pavers will not be stable or carry the same loads.
For large pavers, you need a compacted base plus a thin sand setting bed to eliminate cracks due to stress concentrations or base movement. A large paver has no interlock, so the stability and strength of the surface is less and you can expect some movement and possible loss of the protective sand cushion.
Without a compacted base, the large pavers are almost floating on the base, especially with high moisture contents since the aggregate is not interlocked.
Dick
concretemasonry is offline   Reply With Quote
Old 05-03-2010, 10:06 PM   #8
concretemasonry, can you expand a little bit on the specific base needs for 16 x 16 pavers? Thanks.
Old 05-09-2010, 02:06 AM   #9
Road Base is crushed limestone around here and is 3/4" in size down to fines (dust).
When you use a vibrator compactor with water you will see air bubbling up
from the angular rocks sliding together upon compacting ( and expelling the trapped air).
Use plenty of water , you will know when your using to much.
Accepted minimum paver base thickness is 6" around here for sidewalks and
patios because of heavy clay soils. ( compact in layers).
High Gear is offline   Reply With Quote
240 volt load/appliance and ground vs neutral kgize Electrical 7 04-23-2010 12:40 AM
sub panel ground and neutral daddyrabbit Electrical 3 01-29-2010 07:49 AM
This doesnt seem right. JoulesWinfield Electrical 27 07-26-2009 08:40 PM
Hot Tub Install--Grounding Rod Question statgeek_rob Electrical 16 09-15-2007 03:59 AM
Subpanel feeder questions Silhanek Electrical 4 03-22-2007 07:30 PM
