Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Landscaping & Lawn Care
Old 12-03-2010, 02:14 PM   #1
Grind Bricks Down? ... cause I'm tripping ...
Ok I tore out some brick and concrete to run electrical under ground, then, thinking I want this to be a really good job, I'll just pay someone else to do the concrete and brick work to fill in where I tore things out. However, the guy didn't put them in totally level. There is a good 1/2" rise on one side for a whole row of bricks. (really easy to catch with a foot).
My first thought is ... ... am I going to have to tear these out, and redo them?
My second thought is hmmm, maybe I can grind/sand it down in a way that looks good and doesn't crack the bricks ...
So, are there any tricks, shortcuts, secrets, that I can do to help my dilemma ... or am I screwed and have to rip and and try again?
thanks!
kronic24601 is offline   Reply With Quote
Old 12-03-2010, 02:33 PM   #2
jlhaslip's Avatar
getter ripped up and compacted then replace the bricks.
Go ahead and apply for a variance, those guys at City Hall can use a good laugh.
jlhaslip is offline   Reply With Quote
Old 12-03-2010, 03:29 PM   #3
Master General ReEngineer
Bondo's Avatar
Ayuh,... Most bricks are Harder than most grinding wheels....
Shoulda done it yerself the 1st time I guess...
Old 12-03-2010, 04:28 PM   #4
damn ... that's what I thought. I sorta ran out of time and had someone help with the bricks while I was working on something else ... good help is hard to find I guess. oh well, guess it it what it is. Thanks!
Old 12-03-2010, 05:50 PM   #5
Don't know it all, yet!
Get a diamond blade for an angle grinder for $10-15. Depending how smooth your hand is and how pretty you want it, quick and easy!
If it's worth doing, it's worth doing right. If you wouldn't put your name on it, it ain't done right!
downunder is offline   Reply With Quote
Old 12-07-2010, 05:31 PM   #6
Are your bricks set on bedding material or re-laid on top of concrete? If its on bedding material, you can compact them down. If they are on top of concrete, the best thing to do is lift them and grind the underside of the brick pavers and reset them.
Kurtzilla is offline   Reply With Quote
Old 12-07-2010, 11:14 PM   #7
A Little Of Everything
thanks!
What are these bricks set in/on? If they're pavers, set on sand atop gravel, it's just a matter of tamping them down.
If they're set in the concrete, that's another matter entirely.
DrHicks is offline   Reply With Quote
Old 12-08-2010, 05:00 PM   #8
ya ... they are on top of at least 3-4in of concrete.
Old 12-08-2010, 05:49 PM   #9
I'm sure you've already said this, but, "....aaaaah crap!"
Old 12-09-2010, 02:45 PM   #10
big time ...
Old 12-09-2010, 06:46 PM   #11
big time ...
So now I'm wondering...
If this was my deal I'd HATE to rip it up and start over. That'd be a last resort.
I'm thinking an angle grinder with a masonry blade on it. See what you can do.
Moved Foundation Bricks and Hollow spot? yellowhouse Building & Construction 3 09-28-2010 09:43 AM
Reclaimed Bricks (repointing) soft? davidwarner Building & Construction 11 05-06-2010 10:56 AM
Dead Breaker? and Nusiance Tripping... jasonblu Electrical 9 11-06-2009 07:13 PM
Use stone dust under bricks to form a border around flower bed Curious123 General Discussion 4 08-23-2009 04:41 PM
Paver Sand and Blue/Grey Colored Bricks Curious123 General Discussion 4 08-13-2009 09:22 PM
