Grill Placement On Small Patio - Landscaping & Lawn Care - Page 2 - DIY Chatroom Home Improvement Forum
Old 06-30-2011, 10:18 AM   #16
DIY Hack
Mr Chips's Avatar
Rewards Points: 506
The only thing i would suggest changing is moving the grill to the other corner on that same side, further from the house. Not that you'll burn down the house, but just to help keep the smoke from making the siding black or blowing into the window that looks pretty close to it
Those who can, do...
Those who can't criticize on the internet
Mr Chips is offline   Reply With Quote
Old 06-30-2011, 10:30 AM   #17
Then I risk burning the spruce trees.
dinosaur1 is offline   Reply With Quote
Old 06-30-2011, 10:31 AM   #18
Wind direction is rarely towards the home.
Old 06-30-2011, 10:36 AM   #19
DIY Hack
Mr Chips's Avatar
Rewards Points: 506
Then you are using way too much lighter fluid!!
Personally, I'd move it further from house. if you are happy with it where it is and it works for your needs, happy grilling!!
Old 06-30-2011, 10:47 AM   #20
thanks
Old 06-30-2011, 06:05 PM   #21
Rewards Points: 410
Have you ever been in a hurry and used a 250,000 btu weed burner to
fire up the coals. He he
Balled up newspaper under the lower grill works just as well as lighter fluid.
What time should we be over ??
High Gear is offline   Reply With Quote
Old 07-01-2011, 05:37 PM   #22
How do you guys like it?
What should I do about the patch of grass I'm missing?
Old 07-01-2011, 06:40 PM   #23
concretemasonry's Avatar
Rewards Points: 2,570
I hope you have tried various locations before you assume that the the final resting place. - The photos did not give much information on the wind around the house, no matter what the prevailing winds are since trees and structures alway have more effect on the smoke direction.
Use sod for the missing grass and maybe a little top soil if the digging was too aggresive. Too bad the "solar dog" had to be moved into the shade.
concretemasonry is offline   Reply With Quote
Old 07-01-2011, 07:04 PM   #24
I bought Scotts EZ Seed, good idea?
Old 07-01-2011, 10:41 PM   #25
If the level now is good enough for you, the seed should be O.K. Sod is faster and does help fill localized low areas.
Old 07-01-2011, 10:44 PM   #26
I was also thinking of adding some Tiki torches. not sure how many, where to place them and which ones are reliable.
Old 07-01-2011, 10:45 PM   #27
Overall how do you like the look of the area now, anything you would recommend?
Old 07-02-2011, 10:07 PM   #28
DIY Hack
Mr Chips's Avatar
Rewards Points: 506
looks good fella, like others said, seed if your not in a hurry, otherwise $5 worth of sod will fix that bare spot up nice
Old 07-03-2011, 09:08 AM   #29
Were going to have people who have small kids over for the 4th.
Is it safe to place a plant protector or something over this area for an entire day so nobody steps on it? I used Scotts EZ seed which comes in that gold container.
Small Pavers vs Patio Blocks - Installation Difference snowfiend131 Landscaping & Lawn Care 7 04-17-2012 04:33 AM
Patio ideas for very small area dinosaur1 Landscaping & Lawn Care 4 03-30-2011 05:12 PM
Ideas for deck over concrete patio and beyond-pics- bdobs General DIY Discussions 11 10-22-2010 09:50 AM
Building deck over concrete patio stro77 Building & Construction 8 06-25-2009 05:21 PM
Small Patio Leenders Landscaping & Lawn Care 4 06-23-2006 02:30 PM
