Gravelling A Soggy Yard - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 04-12-2011, 08:28 PM   #1
Rewards Points: 14
gravelling a soggy yard
I want to put down crushed stone on areas of my yard but the yard is still quite soggy from the spring melt. These areas are wet mud. Should I wait untill it gets dryer or can I put down the gravel when its still soggy?
needtoknow is offline   Reply With Quote
Old 04-12-2011, 08:37 PM   #2
Too Short? Cut it Again!
Not sure I understand what you are trying to accomplish here. Are you trying to correct grade of a poorly draining yard with gravel on top?
Anyhow, direct answer is you shouldn't add anything to the problem without expecting all underneath to compact underneath the new weight and just replicate the problem.
Why isn't it draining?
Old 04-12-2011, 10:07 PM   #3
concretemasonry's Avatar
Rewards Points: 2,578
Go to the heart of the problem and correct the drainage that allows the water to collect. Rock and sand to not absorb any moisture, but "bridge" over poor soils for short time until they work down into the soil/muck and the problem will come back again.
Dick
concretemasonry is online now   Reply With Quote
Old 04-13-2011, 08:40 PM   #4
Rewards Points: 14
The purpose for doing this is mainly to keep my dogs from being muddy. We had a lot of rain last summer and fall and a lot of snow so the ground is pretty saturated this year. I will level it out some before I put down the gravel.
Thanks.
Old 04-13-2011, 09:49 PM   #5
Must be valuable dogs that are sensitive to moisture and soil, unless there is another household member that does no like mud. - There are other solutions.
I guess it starting to get muddy now because that soilcan hold moisture for a long time.
Old 04-25-2011, 11:04 AM   #6
Drainage systems Photos and Installations
Simply putting gravel on top of your soggy lawn is not going to help you out for very long. You will need to drain the soil of the water that is seeping into it. A great page detailing french drains and their installation is www.bobcats4hire.com/drainage_systems.htm. It is quite involved to install a drainage system that will work consistently for the long haul, but you will find details and photos of this type of installation here.
mandy12 is offline   Reply With Quote
Old 04-25-2011, 11:12 AM   #7
old guy contractor
tcleve4911's Avatar
Rewards Points: 530
Contact your local landscape company and ask what the Fabric name is that's used to reinforce soggy soil.
Sometimes Paving companies use this under their hot top when soils are unstable.
tcleve4911 is offline   Reply With Quote
How to Grade Forever-Flooded Yard? TheMedicsWife Landscaping & Lawn Care 1 04-12-2010 12:46 PM
Uphill neighbor says I'm flooding his yard.. EdwardC Landscaping & Lawn Care 10 04-11-2010 11:03 PM
Front yard decorating tips jay_chua Landscaping & Lawn Care 1 03-10-2010 08:00 AM
Retaining Wall and Muddy Yard rjschwar Landscaping & Lawn Care 10 02-24-2010 01:55 PM
Well Water ? - No water at yard hydrants... but do have water in house mntnvew Plumbing 73 01-11-2010 09:45 PM
