Gravel For Under Deck - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 04-21-2012, 11:04 PM   #1
Electrician
Rewards Points: 760
Gravel for under deck
I am going to be replacing my stone patio with a wooden deck. I am going to get rid of the old patio stones and want to put some type of gravel under the deck.
The place I buy my gravel from has two different kinds I could use; 3/4" down limestone or a-base gravel. Which one would be better, the idea is to build up some of the low spots and to improve the grading next to the house and to let the water flow away from the house.
darren is offline   Reply With Quote
Old 04-21-2012, 11:23 PM   #2
Rewards Points: 12,808
Gravels not going to improve the grade.
I'd grade it with what around here we call driveway dirt or fill dirt. Then gravel over that if you want to for looks.
Old 04-21-2012, 11:25 PM   #3
Electrician
Rewards Points: 760
They have something called 80/20. 80% top soil and 20% peat moss, is that similar to what your thinking of.
Old 04-21-2012, 11:28 PM   #4
No not even close, that sounds like something to plant a garden with.
This is compatable sand that used when building driveways of back filling where a slab is going to be pored.
Weeds and greass do not like to grow in it.
Old 04-21-2012, 11:57 PM   #5
Electrician
Rewards Points: 760
I don't see anything on there website about stuff like that, maybe since I live in a northern climate they use something different then what your use to.
Old 04-22-2012, 01:00 AM   #6
Maybe, but the point is that you can't use gravel to re direct water, it just flows through it.
Evstarr is offline   Reply With Quote
Old 04-22-2012, 08:47 AM   #7
Electrician
Rewards Points: 760
Just the way they described it on there site it sounded like the water would run off of the 3/4 down instead of through it. I will probably end up getting some type of soil, it is a low deck and once it is done no one will see under it.
Deck Staining Nightmare steven994 Painting 6 04-06-2014 10:10 PM
foundation walls to support a deck bubbler Building & Construction 1 04-12-2012 04:27 PM
Pergola over existing deck cpfullback Building & Construction 0 08-04-2011 12:36 PM
Building a new deck....and creative uses of granite scrap in outdoor living space Rhizzlebop Building & Construction 9 05-15-2009 12:17 PM
