#1 |
Gravel Driveway Base
Hi all,
The paving company has removed the ashphalt on the driveway and will be installing interlocking pavers. The contractor says since the driveway has been there for 25 years, it is alraedy compacted and better to leave the dirt and gravel base undisturbed rather than dig it up to put in new gravel. I have 2 questions: 1) The base appears to be only 40% gravel and 60% dirt or fill. Is the non-100% gravel acceptable. 2) The base is 6'-8" deep not the 12" recommended for a driveway. Does it need the full 10-12". Other than costing the contactor time and money, should I insist on a new base. Thanks for your input. Art |
#2 | |
Gravel Driveway BaseQuote:
#3 |
Having a closer look, it is more like a sand/gravel mixture rather than dirt/gravel. Should I be worried about keeping this as the base.
Thanks, Art |
#4 |
With your revised description you should be OK with the stable, well established base.
Make sure it it graded to parallel the finished grade for the paver surface. Contour the base for drainage and compact any minor filled areas. Make sure the contractor uses the required 1" sand setting bed (uncompacted) that also is screeded to the parallel the final grade, just as the base is so you have a uniform, uncompacted 1" sand setting bed. Your contractor will the lay the pavers tight, install edge restraints, spread some fine surface sand and then vubrate. The vibration will even out the finished surface and draw sand into the joints for an interlock that gives more strength. |
#5 |
I am wondering how it is that by the removal of the asphalt he/(your contractor) didn't disturb the base? With that being said, I would insist he lay down the recommended 10" to 12" required ( or do a build up to 10" to 12") and compact it down. New is new no matter how you slice it. Good Luck to You..........
#6 | |
Don't know it all, yet!
I would break it up, take a bobcat, bucket level, and scoop it up.
If it's worth doing, it's worth doing right. If you wouldn't put your name on it, it ain't done right! |
#7 | |
![]() But your right, New is New!
#8 |
One way to test the job, is to have a super heavy vehicle to part on your driveway for a few minutes then pull out... see if any track left behind... I heard people's driveway got that after a big truck parked over... although it would be a sad story to see... if you are going to do that exercise, make sure you do it before issuing the check...
| Display Modes | |
| Driveway gravel base is too wide. Help | picsaro | Landscaping & Lawn Care | 8 | 09-08-2008 02:56 PM |
| Pouring a concrete slab - Do I need a 4" gravel base? | tokuzumi | Building & Construction | 2 | 11-27-2007 08:40 PM |
| 3/4" Gravel on Sloped Driveway not locking - help? | WynsWrld98 | Landscaping & Lawn Care | 7 | 10-17-2007 12:02 PM |
| gravel driveway | darren | Landscaping & Lawn Care | 4 | 05-15-2007 06:24 PM |
| Gravel Driveway | WildCadillac | Building & Construction | 2 | 05-10-2007 12:53 PM |
