gravel driveway
If, after removing the top soil, your ground is hard and compact then you can probably just put the gravel down. Occassionally, I've found that after digging down a foot I am still in soft soil. Then I will start with sand and rocks to help firm it up - about 2 - 3 inches. I've also put down either landscaping weed barrier or thick plastic ( 4 or 6mil) to prevent any grass growing through and to help prevent the gravel and stones sinking into the soil so easily. If you can, get a roller to help compact it. hope this helps
