Gravel Driveway - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 04-19-2012, 07:46 AM   #1
Rewards Points: 274
gravel driveway
Driveway has small #4's down now. It is a couple of years old. It also has a couple of fairly steep hills. These hills require the most maintenance (w/ tractor box blade) as tires leave ruts when going up. Will putting smaller graver, #57 or smaller, make driveway less "bumpy" driving on, and would these smaller stones require even more maintenance on hills (easier to create ruts in)?? (click pics for larger size)
ugabulldog is offline   Reply With Quote
Old 04-19-2012, 10:53 AM   #2
Rewards Points: 150
I can't see your pictures and I wish I understand some of the terminology that's used in your area, but I'll give you some advice.
What your looking for is a well-graded gravel, meaning it has stone of increasing size in it from 0" to say 5/8" of an inch. Where I'm from that product is called Granular 'M' and is used in driveways, gravel roads and shouldering. It compacts well, is very dense (100% crushed aggregate source) and shouldn't rut seeing that it has a firm sub-grade and normal maintenance. The problem with open-graded aggregates is they don't knit together well and the aggregate interlock is non existant. Although the drainage characteristics can't be beat.
In short, look for a well-graded aggregate, from a crushed stone source with the biggest stone being 5/8" or 3/4".
psilva8 is offline   Reply With Quote
Old 04-19-2012, 01:15 PM   #3
Civil Engineer
Rewards Points: 4,560
Any gravel driveway in wet areas on a hill is going to require constant maintenance, short of building it with large interlocking stones (essentially pavers). But if you were going to do that, you might as well pave the road.
The small stone is easily moved by tires, creating ruts. Larger stone moves less easily, but the ride is not as smooth. For my money, I would go with larger stone, a little less maintenance, and a little bumpier ride.
Old 04-19-2012, 01:23 PM   #4
Rewards Points: 274
thanks to both.... I was told that adding smaller stone on top of the larger would create smoother, but I was thinking that the smaller stones would fall dwon between the larger and essentailly not be of benefit. If I understand you correctly, you are in agreement...
Old 04-19-2012, 06:47 PM   #5
Civil Engineer
Actually I did not realize you intended to add small stone over larger stone. That is a good plan, since the small stone will fill voids in the large stone, locking together, and will make for a more durable, though certainly not maintenance free, surface. I thought you were wondering about the difference between a surface composed entirely of small stone versus a surface composed entirely of large stone. A graded mix is always going to be better in terms of durability.
Landscape fabric under gravel driveway? jpsmith Landscaping & Lawn Care 15 12-09-2012 10:24 PM
Gravel driveway elmaur Concrete, Stone & Masonry 2 04-16-2012 11:44 PM
Muddy gravel driveway Ack Landscaping & Lawn Care 3 02-10-2009 03:38 PM
Gravel Driveway Base atw58 Landscaping & Lawn Care 7 09-22-2008 04:01 PM
3/4" Gravel on Sloped Driveway not locking - help? WynsWrld98 Landscaping & Lawn Care 7 10-17-2007 12:02 PM
