Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Landscaping & Lawn Care
Old 09-24-2010, 02:48 PM   #1
Gravel Drive
My gravel driveway is packed hard and has no potholes, but it also has a lot of grass and weeds. I've recently taken to mowing it. How should I prepare the drive before I lay new gravel and how do I prevent the gravel from traveling into the lawn?
j.kaye is offline   Reply With Quote
Old 09-24-2010, 04:22 PM   #2
DIY Hack
Mr Chips's Avatar
Gravel Drive
Weeds and grass are tough to permanetly get rid off in a gravel driveway. It's a constant struggle. You can use a chemical herbicide in spring and fall, or if you want a more eco-friendly approach you can use salt and boiling water. Corn gluten as a preimergant might work. You could try raking them out as well. You could do nothing but mow as low as possible, and just add gravel on top, which might choke out a lot of it by not allowing it to get sunlight. No matter what you do, be prepared to do it or a combination of things a couple times a year.
As for keeping gravel out of the grass, edging or some type of curbing are really the only thing i can think of.
good luck
Those who can, do...
Those who can't criticize on the internet
Mr Chips is offline   Reply With Quote
Old 09-24-2010, 11:50 PM   #3
Gravel Drive
How about putting down a landscaping fabric --but you'd need to take away most of the gravel, put it down and then put the gravel on top.
Allison1888 is offline   Reply With Quote
Old 09-25-2010, 10:30 AM   #4
concretemasonry's Avatar
Gravel Drive
Fabric is very often useless since many of the weed seeds are airborn and they can can settle in the gravel and sprout.
Dick
concretemasonry is online now   Reply With Quote
Satellite Rx external hard drive. Wildie PC Repairs & Upgrades 4 09-14-2009 12:06 AM
Moving C drive files Thurman PC Repairs & Upgrades 14 08-17-2009 04:13 PM
Hard drive redline PC Repairs & Upgrades 14 03-06-2009 05:27 PM
Muddy gravel driveway Ack Landscaping & Lawn Care 3 02-10-2009 03:38 PM
concrete funnel for gravel? Moritz Building & Construction 5 04-13-2008 10:07 PM
