-   -   Gravel Drive (http://www.diychatroom.com/f16/gravel-drive-82252/)
j.kaye 09-24-2010 01:48 PM
Gravel Drive
My gravel driveway is packed hard and has no potholes, but it also has a lot of grass and weeds. I've recently taken to mowing it. How should I prepare the drive before I lay new gravel and how do I prevent the gravel from traveling into the lawn?
Mr Chips 09-24-2010 03:22 PM
Weeds and grass are tough to permanetly get rid off in a gravel driveway. It's a constant struggle. You can use a chemical herbicide in spring and fall, or if you want a more eco-friendly approach you can use salt and boiling water. Corn gluten as a preimergant might work. You could try raking them out as well. You could do nothing but mow as low as possible, and just add gravel on top, which might choke out a lot of it by not allowing it to get sunlight. No matter what you do, be prepared to do it or a combination of things a couple times a year.
As for keeping gravel out of the grass, edging or some type of curbing are really the only thing i can think of.
good luck
Allison1888 09-24-2010 10:50 PM
How about putting down a landscaping fabric --but you'd need to take away most of the gravel, put it down and then put the gravel on top.
concretemasonry 09-25-2010 09:30 AM
Fabric is very often useless since many of the weed seeds are airborn and they can can settle in the gravel and sprout.
Dick
