Grass Removal - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 03-28-2012, 09:55 AM   #1
Rewards Points: 81
Grass Removal
I have a line of about 20 Thuja Green Giants that are spaced approx 6 feet apart. They are currently about 8 feet tall. When I planted them a few years back (2 foot tall), I made the mistake of just digging out the sod for each planting hole. What I would like to do is to remove all of the sod between each tree, and remove about 2-3 feet of grass on either side to make 1 long bed. I would then fill this all in with mulch. Objective is to remove the competition between the grass and the Thujas. What is the best way to remove this grass? Sod cutter? Round-Up? My concern is if I use Round-Up, would it have any affect on the Thujas or would it just kill the grass that I would spray it on? I would use a hand held pump sprayer, so I would (hopefully) be able to keep the spray area under control. Suggestions? Thanks!
cougar01 is offline   Reply With Quote
Old 03-28-2012, 09:59 AM   #2
Rewards Points: 14,306
Round up may also kill the trees.
I'd use a roto tiller.
Old 03-28-2012, 10:47 AM   #3
Learning Things Every Day
Jay 78's Avatar
It seems like simply laying down the mulch on top of the grass would be enough to kill it. Not so?
Under Construction
Jay 78 is offline   Reply With Quote
Old 03-28-2012, 11:28 AM   #4
Too Short? Cut it Again!
Round-up should not hurt the surrounding plants so long as you do not get overspray on them. It is a post-emergent, systemic herbicide that works specifically on killing the systems of plants only to which it is applied. It is non-selective in killing all to which it is applied though.
You risk doing more damage to the roots of the plants you want to preserve getting rototiller blades too close to them. One of the little rototiller might work but they tend to bounce around quite a bit.
It will take you a while but cut the sod with a spade and get rid of it. Or you could rent a sod cutter I guess. Then turn the soil over of with a shovel or soil turning fork. Add your mulch.
Old 03-28-2012, 11:37 AM   #5
bbo
you can also "paint" on the roundup to avoid having overspray getting on the items you do not want killed.
bbo is offline   Reply With Quote
Old 03-28-2012, 11:44 AM   #6
I'd edge out the line or shape you want the space to take and simply lay a thick layer of newspapers on the sod and top with woodchips or whatever you are mulching with. That will kill the grass chemical free and be a whole lot less labour intensive
creeper is offline   Reply With Quote
The Following User Says Thank You to creeper For This Useful Post:
bbo (03-28-2012)
Old 03-28-2012, 09:26 PM   #7
Jay 78's Avatar
I guess that's a 'yes'....
Under Construction
Old 03-28-2012, 09:47 PM   #8
Rewards Points: 81
Thanks!
Planting grass under old tree rightit Landscaping & Lawn Care 12 05-06-2011 08:53 AM
"soccer-resistant" grass or 2nd best? ilyaz Landscaping & Lawn Care 3 01-25-2011 06:04 AM
How to identify lawn grass types findlay70 Landscaping & Lawn Care 1 07-06-2010 08:10 PM
Smoke or steam coming from grass Holt Landscaping & Lawn Care 0 11-05-2009 10:53 AM
Swapping grass varieties... opinions? joeyboy Landscaping & Lawn Care 5 03-11-2008 08:06 PM
