Grass Issue - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 04-07-2013, 12:33 PM   #1
FordRacer2007's Avatar
Rewards Points: 29
Send a message via Skype™ to FordRacer2007
Grass Issue
I recently bought a small swing set for my kids and now that lawn mowing season is here I realize that not only does the weed eater tear up the wood, but the grass is impossible to get to in certain areas of the swing set.
I figure the easiest and cheapest thing to do is get rid of the grass, somehow enclose the swing set so I can pour some sand around it. My question is, what is the easiest way to get rid of the grass, and what can I use to make the border around the swing set?
Any suggestions are also welcome if there's a better solution to this, thanks!
Attachment 68706
FordRacer2007 is offline   Reply With Quote
Old 04-07-2013, 12:48 PM   #2
Rewards Points: 1,652
If there is any chance of a feral cat in the neighborhood you'll regret sand .
SeniorSitizen is offline   Reply With Quote
Old 04-07-2013, 12:57 PM   #3
Rewards Points: 29
Ah thanks, wasn't aware of that.
Old 04-08-2013, 05:59 PM   #4
Rewards Points: 744
Roundup will kill grass fairly well. There are also several organic burn-out products that work very well. http://www.planetnatural.com/site/xd...Weed%20Control
How about woodchips, instead of sand?
Seattle2k is offline   Reply With Quote
Old 04-08-2013, 10:08 PM   #5
Rewards Points: 12
Another thought... Instead of trying to kill the grass, you can rent a power sod cutter for about $50 and take it out in about a half hour.
I also went with wood chips. Considered the alternatives... sand attracts critters and gets dirty. Or you can do pebbles, but when the kids move out you have to get rid of them. Hence wood chips. I figure if they break down I can add more to the top... and if I ever want to get rid of the swingset and restore the area... the wood chips just compost down into dirt and can be spread all over the place.
I was able to get special wood chips intended for playsets from a local supplier. Cost around $30/yard. Needed like 10 yards to cover the area, but they're light and it's good exercise with the wheelbarrow.
MinnesotaSteve is offline   Reply With Quote
Old 04-08-2013, 10:44 PM   #6
Too Short? Cut it Again!
Recycled shredded rubber comes in all colors including some you cannot tell from wood chips until you get up close. It will not decompose like wood chips will over time or put splinters in the little ones. Theoretically they will bounce better off of it when the fall too.
Old 04-09-2013, 03:55 AM   #7
Rewards Points: 29
Thanks guys, this was all very helpful.
Old 04-09-2013, 12:54 PM   #8
Rewards Points: 12
We actually had some of these under our swingset that the previous owners had put down. Not enough to be useful, they were mixed up with the mud and grass. Took me a long time to get them out of the dirt, and I'm still finding the pieces today.
I called around and the only way to dispose of them was the landfill.
Old 04-10-2013, 09:02 AM   #9
Good point. There is a recommended depth for any mulch, bark or whatever under playground equipment and I do not remember what it is.
Obviously you would have some of the same problems with wood but it should eventually decompose.
Old 04-10-2013, 11:46 AM   #10
Rewards Points: 744
If going for the rubber chunks, it would be wise to put down a layer of landscaping fabric first. This will make disposal easier down the road, when the kids have outgrown the playset.
Old 04-10-2013, 03:12 PM   #11
Well again, and not trying to talk you into the rubber product, but landscape cloth of a heavy enough grade and suitable material not to fall apart itself, would be good under bark chunks too.
Boulevard grass has many species of grass criel Landscaping & Lawn Care 1 07-21-2012 06:51 AM
Watering your grass UMWolve Landscaping & Lawn Care 2 03-25-2012 05:34 PM
Grass Barry J Landscaping & Lawn Care 2 02-22-2012 01:30 PM
Drainage issue and need suggestion on type of grass golfer2b Landscaping & Lawn Care 9 03-24-2008 07:38 PM
Drainage, grass issue. Bcoleman6 Landscaping & Lawn Care 2 03-22-2008 11:53 AM
