Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Landscaping & Lawn Care
Old 06-11-2010, 04:23 AM   #1
Question
Grass between Pavers
I have a large dirt area in the backyard that I would like to cover using large block stepping stone. I would also like to grow Korean Grass between 6 inch space between each stone. I was planning on simply laying down the stone, digging 2-3 inches deep between the stone and installing irrigation and planting the seeds with soil. Should I install drip irrigation? How deep should i install?
haveyouseen is offline   Reply With Quote
Old 06-11-2010, 09:34 AM   #2
Xtreme DIY'r
Where are you located ?
Old 06-11-2010, 10:37 AM   #3
that looks like fun to maintain
chenzarino is offline   Reply With Quote
Old 10-05-2010, 08:59 PM   #4
Hi, I love the look of the cement pavers and the grass. I am geting ready to put pavers down but what type of grass is used in the picture? Will it live in Florida? We are putting the pavers down with paver sand which has lime in it. Won't that kill the grass?
Susan
Skutz39428 is offline   Reply With Quote
Old 10-06-2010, 10:29 PM   #5
I like the look, but it seems like a nightmare to maintain. Can you mow the grass over the stones?
Allison1888 is offline   Reply With Quote
Old 10-07-2010, 07:47 AM   #6
HI, I guess either the 'OLE" hands and kness with a sissor or a weed eater. But I am concerned about the lime that is in paver sand. So now I am thinking about that recycled glass in green. There are so many low maintnece grasses to put in between to get that look but I think the grass will die from the lime?
I am located in Florida.
Old 10-10-2010, 06:38 PM   #7
The grass will grow in the sand but it will grow poorly because of a lack of organic matter and nutrients.
If the sand has lime in it the grass may not grow.
The best way to get the grass between the pavers is to install the pavers onto the base wether it is packed crushed gravel or sand, which ever the design dictates. Then the backfill between the pavers is done with sandy or sandy loam soil. Excessive loam (clay) in the soil will reduce water permiability and can lead to puddling.
For watering the best method is using a sprinkler and water the entire area. A drip irrigation system will save alot of water but in this application it may not be so well suited. Watering the whole area is important becasue it will not only water the grass but it will also cool the bricks. This may be necessary becasue of the amount of heat the bricks will absorb during the day could cause the soil to warm to a temperature that is fatal to the grass.
jasoninct is offline   Reply With Quote
Pavers over a concrete sidewalk Beckerad Flooring 3 07-20-2010 09:59 PM
Help! Paver patio with standing water toeey1 Landscaping & Lawn Care 11 04-05-2010 07:54 PM
Smoke or steam coming from grass Holt Landscaping & Lawn Care 0 11-05-2009 11:53 AM
Brick pavers on driveway ???? sflamedic General Discussion 2 04-21-2008 12:12 PM
Swapping grass varieties... opinions? joeyboy Landscaping & Lawn Care 5 03-11-2008 09:06 PM
