Grading Dirt In Backyard Question - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 05-31-2013, 01:11 AM   #1
Rewards Points: 264
grading dirt in backyard question
I am removing my old concrete patio and dirt in backyard because the combination of the the two is too high. I am bringing the dirt down to about 6" below the vents going into the crawlspace that are part of my raised foundation. Does anyone know how many inches to drop the grade going away from the house? Is it like 1 inch every 10 feet? Thanks
Pawl is offline   Reply With Quote
Old 05-31-2013, 01:35 AM   #2
Rewards Points: 264
just saw a you tube video that said the grade should drop 1 inch every foot coming away from the house. Then I saw another one said 1/4" to 1/2" every 10 ft,then I saw another you tube video said 1" every 4 feet. It just keeps getting better.
Old 05-31-2013, 03:57 AM   #3
GBrackins's Avatar
Rewards Points: 2,108
the greater the slope the faster you move water away from your home and foundation. Most building codes require a 6" drop within 10' of the foundation.
Gary
"You get what you pay for, and sometimes free costs more!"
GBrackins is offline   Reply With Quote
The Following User Says Thank You to GBrackins For This Useful Post:
Pawl (05-31-2013)
Old 05-31-2013, 09:54 AM   #4
Roofmaster
Rewards Points: 2,172
I would say at least a 1/4 inch per foot. That is code for low slope roofs, and plumbing. A little more would be better if you can do if as roofs and pipes are impermeable (Hopefully)
The Following User Says Thank You to jagans For This Useful Post:
Pawl (05-31-2013)
Old 05-31-2013, 10:42 AM   #5
Rewards Points: 33
2% minimum away from the house. Some cities are requiring 5% minimum for 10-15' from the house.
1" per 10' is .83% slope. 1" per 4' is roughly 2%.
House Adventures our Blog about finding a house in Los Angeles and lightly renovating it.
buzzkillb is offline   Reply With Quote
The Following User Says Thank You to buzzkillb For This Useful Post:
Pawl (05-31-2013)
Old 05-31-2013, 10:51 AM   #6
JOATMON
ddawg16's Avatar
Rewards Points: 1,116
Your in California.....a heavy rain here is just a sprinkle in Texas.
But compounding your problem is the clay dirt we have...once it's gets wet...it's like a plastic tarp...water just sits on top.
I think your going to be fine with 2% or 1/4"/ft.
If you have any areas that it looks like it will be hard to get the water away from...dig a trench and make a French drain.
The Following User Says Thank You to ddawg16 For This Useful Post:
Pawl (05-31-2013)
Old 06-01-2013, 11:01 AM   #7
Rewards Points: 264
I will probably go with the minimum % on this project. I should have mentioned some other things that play into the minimum decison. I have 3' eaves and rain gutters around my whole house which helps keep what little rain we do get in Calif (10"-if we are lucky) away from the house. I realized one day that the storm drains for our tract are at the other end of the tract meaning to me that I am at the high end of the tract if there is such a thing.I have watched rain easily move away from my house on rainy days. I am not certain if I am wrong about this as I only have watching the as my testament to this theory.
My whole reason for asking this grading question is the previous owners who bought the house is 1965 had a concrete patio put in the backyard with a walkway on the northside. The people doing the work never graded the elevation so the top of the patio is almost level with the vents for the crawlspace. It is my understanding that the grading needs to be at least 6" below that vent so I am tearing out the completely cracked all over patio and removing the necessary amount of dirt to accomplish this feat. Big job but great exercise. So I think with all the other positives I have going to remove water I should be fine with minimum % grading. See pictures that show top of concrete is under the vent. Plus I have to replace sill plate and rim joist that has rotted over time.
grading dirt in backyard question-house-floor-plans-078.jpg   grading dirt in backyard question-house-floor-plans-076.jpg   grading dirt in backyard question-house-floor-plans-070.jpg
Generator connection Question - Final Plan Apollo67 Electrical 24 01-30-2012 08:44 PM
Basement Renovation Question KUIPORNG Remodeling 234 08-26-2008 09:19 AM
Is there a proper fill dirt for grading? Sonabi Landscaping & Lawn Care 2 04-19-2008 12:23 AM
Basement vapor barrier question rob7young Remodeling 2 04-13-2008 10:10 AM
backfill question. joshm General DIY Discussions 4 03-25-2008 05:46 PM
