Grade Help Near House - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 03-14-2014, 11:22 AM   #1
Rewards Points: 248
Grade help near house
Hello, with the spring melt this year I am having water leak into my basement. There is a pool of water a few feet from my house. So this spring/beginning of summer I am planning on increasing the slope by my house.
Here is my plan. Let me know if this sounds good or any advice.
1.Lay decorative brick to outline the flower bed. I'm thinking the brick will stick out of the ground some so it is visible. Not sure how high yet.
2.Bring in dirt and increase the grade from house to top(near top) of brick. Thinking 5% slope should work.
3. Lay fabric, and then lay mulch on top.
Questions I have.
If I grade the soil 5%, does the mulch have to be graded at that too? Can that be even? or maybe just a lesser slope?
Would putting in a french drainage system in be overkill? And if not over kill I was thinking of putting that in the middle of the flowerbed 2 to 3 feet from foundation and only like a foot deep.
Let me know what you guys think.
jburchill is offline   Reply With Quote
Old 03-14-2014, 12:03 PM   #2
Master General ReEngineer
Bondo's Avatar
Rewards Points: 992
Questions I have.
Ayuh,....#1, yer buildin' a Dam at the top,..??
#2, most of the time, the grade is Already too high, ya might consider Removin' material, rather than addin' material,....
#3, Yer fabric, 'n mulch should be figured in, Before ya start,....
Not added after the fact,...
Bondo is online now   Reply With Quote
Old 03-14-2014, 02:18 PM   #3
Rewards Points: 248
Not sure how that would be a dam at top. Here is what it would look like, but not as high as the pic.
If I'm building it up, I'd have to add dirt to the front and back. More build up at the house to create the slope.
Old 03-14-2014, 03:21 PM   #4
Rewards Points: 13,446
I know, not think that having a flower bed or mulch piled up against a foundation is a sure way to hold in moisture, not direct it away.
Posting a picture is a great way to show us what your looking at.
A French drain is a great idea.
Cape Cod Style House Attic/Crawl Space Insulation Help Danielg Insulation 24 05-21-2012 08:20 AM
Best way to grade for drainage around house? Bahuffma Building & Construction 7 08-01-2011 12:51 AM
Considering buying a house that needs regrading HELP Dr.JUSC Landscaping & Lawn Care 9 06-16-2011 10:58 AM
Trane XR12 1.5 ton-Too small for my house? Badfish740 HVAC 7 09-23-2009 05:48 AM
I have Central Heating & Air, but house won't cool down..HELP!! exiledone1 HVAC 13 07-10-2009 10:09 PM
