Got Some Overgrown Scraps Of St Augustine Today - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 12-28-2011, 02:10 AM   #1
I love my new front yard!
Telfair's Avatar
Rewards Points: 158
Got some overgrown scraps of St Augustine today
From my local nursery & dug a bit & also basically just laid it in place & hosed it down good hoping it take hold but to be honest as over grown as this grass is I'm a wee bit concerned about how mowing it will work out?
I dont wanna kill it on it 1st mow.....?????
I'm told it should fill in well on its own in about 6 months & have come to realize that if this take hold maybe I can just take lots of plugs from it to finish the back yard... About 1000 sq feet.????
Telfair is offline   Reply With Quote
Old 12-28-2011, 08:58 AM   #2
Rewards Points: 150
Yes you can do it if you keep it watered when you first sprig it. I sprigged my whole back yard (80'x100') with St Augustine. It took several years to get established but I wasn't able to water it and we've had a lot of drought years here lately.
Set your mower blade really high, or maybe just use a string trimmer to keep the height down a little until it gets well established. It spreads with runners. Looks good!
NancyNGA is offline   Reply With Quote
Old 12-28-2011, 01:47 PM   #3
Telfair's Avatar
Rewards Points: 158
It took years!?!?!?!?!
Old 12-28-2011, 04:10 PM   #4
Rewards Points: 150
Well, it depends of course on how many sprigs you have to work with, and whether you have bare ground to start with. I was using little sprigs and spacing them a couple of feet apart. Already had some crummy grass on the lawn. The St. Augustine eventually took over. It wasn't my top priority at the time.
Old 12-29-2011, 06:50 AM   #5
Too Short? Cut it Again!
Also depends on whether you bothered to prep the soil for planting!
You cannot expect any turfgrass to grow well in unprepped soil. The prep is the same for seed, plugs, sod, hydromulcing/hydroseeding, etc. Skip it and your fate is cast to the wind.
And as just shared. Turfgrass of any kind takes lots of water to maintain. You might be better off really thinking through how much turf you want and planting nicely colored and textured groundcovers instead where you do not need actual turf.
Old 12-29-2011, 08:27 AM   #6
Telfair's Avatar
Rewards Points: 158
My front lawn is Fescue, but I want St Agustine in the back yard because of the dog I'm getting...
Hot water heater getting VERY hot all of a sudden today bgbrown125 General DIY Discussions 20 12-04-2011 07:04 PM
Baseboard Gap Options? Installing Floating Vinyl Flooring Today. Please Help. skeeter505 Flooring 1 09-17-2011 08:46 AM
plywood/ osb scraps for sheathing? nicole21 Roofing/Siding 4 09-08-2010 11:41 AM
