Got Crabgrass Big Time In Allen, Texas - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 04-19-2011, 12:14 PM   #1
Rewards Points: 12
Unhappy
Got crabgrass big time in Allen, Texas
I applied the pre emergent and I am told due to the cold weather in our area that it did not do its job so I look others have a yard full of crab grass. I have not been able to get any good input by googling on the web regarding which would be the best chemicals to use for this weed. It seems like the traditional Ortho and others are so watered down that repeat treatments are the order of the day. Does anybody have any success stories in this area. Thanks
rommel is offline   Reply With Quote
Old 04-21-2011, 12:35 PM   #2
Hey, rommel. Ken here with The Home Depot in the Chicago area.
Crabgrass is a problem all over the country. The chemicals being
watered down isnít the problem. Itís the cold weather. The fluids in
the plant arenít moving very fast. When itís cold and you spray, the
chemical takes a long time to be translocated to the roots. Sometimes
it doesnít get there. Once it gets warmer and the fluids are moving faster
you will get better control. Spray again when itís warm.
Good luck and take care.
hortman is offline   Reply With Quote
Old 04-21-2011, 05:32 PM   #3
Too Short? Cut it Again!
If you already have crabgrass a pre-emergent will have no effect whatsoever. You need a post-emergent herbicide now. Many of the best for crabgrass require an applicator license, permits and so forth so you may find it cheaper than wasting money on consumer products to call a turfgrass or lawn maintenance company with them to help you out.
Sump Pump cycles 3-8 times each time it runs Delegator Plumbing 2 04-06-2008 01:48 PM
First time vinyl siding newbie plus windows justdon Remodeling 9 02-06-2008 07:39 PM
Houston Texas Floorwizard Off Topic 2 01-22-2008 12:17 PM
Furnace's blower is on all the time but gas burner does not start artgue HVAC 3 01-16-2008 06:46 PM
Applying Crabgrass Halt gregt848 Landscaping & Lawn Care 1 05-02-2007 04:01 PM
