Goofy Expansion Joint Question - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 06-08-2012, 10:07 AM   #1
Goofy expansion joint question
I am pouring an 8' x 12' slab off the back of my house to place the air conditioner and stairs leading to a paver patio. The block that makes up the foundation of the addition I will be pouring against is not flat, but cast block to look like stone? The "cast face" of the block protrudes about 3/4" so I am wondering how to create my expansion joint. If the block were flat I throw down some 1/2" expansion joint and pour away. Since the "cast face" protrudes if I place the expansion joint against the block I will end up with 3/4" gaps where the slab meets the wall. Any suggestions how to proceed? I also do not plan on pinning the slab to the block. The clay base will be compacted and then 4" of 57 limestone compacted, then 4" slab.
614Brewer is offline   Reply With Quote
Old 06-09-2012, 07:04 AM   #2
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,612
Ayuh,.... Go ahead, 'n do it, then caulk the remainin' seam/ gap with concrete caulkin'...
Old 06-09-2012, 08:32 AM   #3
Ravenworks's Avatar
Use foam expansion joint,do not't remove the key before you caulk.
I used two different caulkings to do mine,the first was a stiff polyurethane caulk to help bridge any large gaps ,after it is cured I then used a self leveling polyurethane over top
U.S.M.C. "80-84" E.O.D. 1369
Ravenworks is offline   Reply With Quote
Concrete Path Against Foundation without Expansion Joint Baoh Building & Construction 2 11-20-2011 03:14 AM
Laminant flooring question mort5029 Flooring 0 12-29-2010 12:52 PM
Plaster to drywall joint question. ERIK2173 Remodeling 7 05-16-2009 04:58 PM
expansion joint farrington135 Building & Construction 1 01-27-2006 10:02 PM
joint compound question golfer General DIY Discussions 3 01-09-2006 06:19 AM
