Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Landscaping & Lawn Care
Old 02-05-2008, 03:20 AM   #1
glue for drain pipe?
I bought some drain pipe from Home Depot to make a drainage system around my house. The white tubes that come in 3" or 4", 10 ft lengths. The pipe says it is styrene pipe.
Can I use the same glue I use for PVC pipe?
tikicarver is offline   Reply With Quote
Old 02-05-2008, 04:04 AM   #2
Problem Solver
Nope, I don't think so. An ABS pipe comes with it's own specific glue, and should be used accordingly. You can't mix and match them.
nvhost is offline   Reply With Quote
Old 02-05-2008, 12:55 PM   #3
remodeling pro
ABS it has it's own glue as nvhost says. They do make a multi purpose glue that can be used on both ABS and PVC , but it is not as good as ABS glue for ABS pipe and not as good as PVC glue for PVC pipe, according to my plumber, so just buy the right glue, it is not a major investment.
troubleseeker is offline   Reply With Quote
Old 02-05-2008, 05:36 PM   #4
I know there are different glues but all I see in the store is glue for ABS, PVC, CPVC. The pipe says it is styrene. So are you saying ABS glue will work with styrene?
Old 02-05-2008, 05:45 PM   #5
ABS=Acrylonitrile-Butadiene-Styrene
Randell Tarin is offline   Reply With Quote
Old 02-05-2008, 06:10 PM   #6
Res Ipsa Loquitur
In most home stores (HD & Lowes), ABS is usually the black hard plastic drainage (DWV) pipe sold, the white (DWV) pipe is usually PVC.
Did you ever stop to think, then forget to start again?
handyman78 is offline   Reply With Quote
Old 02-05-2008, 07:01 PM   #7
the stuff I got from HD is white on the outside and black on the inside. It has white plastic hub on the end, the pipe fits snuggly into the hub. All it says on it is "styrene".
It is not the same as the white PVC pipe used commonly in bathroom/kitchen plumbing.
Old 02-06-2008, 12:18 AM   #8
Problem Solver
Well if it says it's Styrene, then use the ABS glue. And considering it's going to be a drainage system, you better use the right glue. It's hard to fix up drainage problems later on
Old 02-07-2008, 10:03 AM   #9
Journeyman Plumber
Ron The Plumber's Avatar
That type of pipe is used in sepic leach fields.
Fix it right the first time, so you won't have to fix it a 2nd time.
Ron The Plumber is offline   Reply With Quote
Broken pvc pipe Keyo77 Plumbing 21 10-20-2007 04:57 PM
PVC pipe broken on Gas Furnace/AC unit Keyo77 HVAC 8 10-16-2007 04:08 AM
Replacement pipe for hot water heat? Tmb9862 HVAC 18 01-12-2007 04:31 PM
Need to support 15th of ABS pipe irishtimes101 Plumbing 3 09-01-2006 12:09 PM
