Glazed Clay Pot - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 06-04-2011, 03:45 PM   #1
glazed clay pot
can drylok be used to coat the inside of a glazed clay pot ( that is going to be used for a fountain) to keep it from leaking? It apparently is still porus.
jmlaroe is offline   Reply With Quote
Old 06-04-2011, 04:00 PM   #2
the Musigician
DangerMouse's Avatar
Hi and welcome to the forum.
I'd guess yes. I see no reason why it would not work.
DM
Old 06-04-2011, 11:49 PM   #3
Too Short? Cut it Again!
I guess too but why worry if it is a nice, quality ceramic pot? Haven't such things and water sort of gone together for millenia? I would never seal both sides of ceramic piece for the reasons you suggest.
You can try sealing it but if it oozes I suppose but you deny it the clay its quality of life and it will not last long I fear. You may find that once the water swells the clay shut it will be just fine.
Otherwise, and no offense, my a clay piece better fired and with denser structure to be used as a fountain.
Old 06-05-2011, 07:03 AM   #4
DIY staff
Rewards Points: 7,174
I suggest that you use HydroBan or Red Guard----Kind of expensive but that's what Hydro Ban is designed to do.(Latacrete makes Hydro Ban)
installing sonotubes on mucky clay Metal Man Building & Construction 0 05-20-2011 09:29 PM
Compacting wet clay for foundation phil89 Building & Construction 0 04-28-2011 02:43 AM
clay cap around foundation? patrickosu Building & Construction 5 08-21-2010 05:55 AM
Clay Soil Vs. Grass mahjohn Landscaping & Lawn Care 6 08-20-2010 08:43 PM
Removing clay stains from asphalt ljcox General DIY Discussions 6 05-15-2009 09:54 PM
