Gas Or Electric - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 11-30-2012, 02:40 PM   #1
Rewards Points: 278
gas or electric
I am considering electric lawn mower which is only used for the backyard, the
furthest lawn away from the house is about 35 ft, first 10 feet is the patio.
maybe 30 ft across. so under 1000 sq ft.
75'-100' cord? Would it become really annoying?
I am thinking the electric mowers are smaller and lighter and I may also be bringing it between properties.
DIYGST is offline   Reply With Quote
Old 11-30-2012, 05:56 PM   #2
Rewards Points: 13,296
Concider a battery powered one instead. I can not see draging around an extention cord when mowing a lawn. At some point you will run it over.
http://www.bing.com/shopping/search?...RM=HURE#x0y265
Old 11-30-2012, 05:59 PM   #3
Rewards Points: 278
it's hard to consider a battery powered one
I always feel the battery will run out before the job is done, or the quality of the battery degrade quickly, maybe they have gotten alot better but that happened with my trimmer.
Old 11-30-2012, 06:34 PM   #4
Too Short? Cut it Again!
A girlfriend had a battery mower. Black and Decker I believe but don't trust my memory. It used golf cart type batteries and they had no trouble doing 1,000 sf of lawn between charges. As I remember, they only lasted a couple seasons though. The machine had nice torque. Most corded mowers do not seem to have such.
Nothing against corded mowers save for the cord always seems to get in the way no matter what you try. It is certainly easy enough to work around. They are what they are.
There are some new and improved person powered reel mowers out there these days. I have seen people fly through mowing their lawns with the things.
Old 11-30-2012, 07:52 PM   #5
Rewards Points: 2,634
I was going to say they last 5 or 6 years. The batteries die, and then you don't want to spend the money on an old mower to fix it. Plenty of capacity to do most yards though, and no cord. Maybe they have better batteries now.
SPS-1 is offline   Reply With Quote
Old 11-30-2012, 09:31 PM   #6
Electrical Contractor
jbfan's Avatar
Rewards Points: 240
Get a robotic lawn mower, and never cut grass again!
jbfan is online now   Reply With Quote
The Following User Says Thank You to jbfan For This Useful Post:
Missouri Bound (12-31-2012)
Old 11-30-2012, 09:37 PM   #7
Will never forget an early one that made a run for it! Some rich guy in Champaign Urbana had one and I guess it got confused by a silent dog fence and could not recognize the frequency that was supposed to keep it in the yard. Off it went merrily mowing neighboring lawns.
Old 11-30-2012, 09:57 PM   #8
JOATMON
ddawg16's Avatar
Rewards Points: 1,122
I keep hoping my gas mower will die so I can go cordless......
With cordless....there is:
No gas to put in....
No air filter to clean....
No oil to change....
Quiet....
No smell of gas in the garage when storing it...
If you look at the total cost of ownership of a cordless vs gas....cordless is cheaper....add of the cost of gas....and the time and gas to go fill up the gas can....much more than the electricity to charge the mower....
Old 12-01-2012, 05:08 PM   #9
Rav
Rewards Points: 552
I have a Black and Decker CMM1200 battery-powered mower, which I've had now for almost 10 years. It started life as a CMM1000, and in 1996 B&D had a recall for it due to an electrical problem, and they converted it to a CMM1200, totally for free (at a local equipment rental place that does warranty repairs). I love it. No cords, no gas. I have a total of 2,900 sq. ft. between the front and back yards, and it doesn't run any slower by the end of mowing it all, so it has capacity to spare. I don't think they make that particular model anymore but a quick check on their web site shows a number of CM models they offer now. They're not inexpensive but I think they're worth it.
Rav is offline   Reply With Quote
Old 12-30-2012, 07:58 PM   #10
I am waiting for the one that you screw on a propane cylinder. http://www.popsci.com/environment/ar...eener-pastures
paintdrying is offline   Reply With Quote
Old 12-31-2012, 11:34 AM   #11
Missouri Bound's Avatar
Quiet....
Since you can purchase 4 gas powered mowers for the cost of one electric...I'd say gas is more economical. Plus if you skip a week or two of mowing the electric probably will struggle, the gas will not.
Do you want it your way or the right way?
Old 12-31-2012, 12:14 PM   #12
JOATMON
ddawg16's Avatar
Slight exageration?
A quick check using Amazon......
Prices for the cordless range from $179 to $379
Prices for gas powered.........about the same.....
So....I can buy a cordless mower for about the same price as a gas powered...not sure how you came with with 4.
Old 12-31-2012, 01:19 PM   #13
Using your $379 number. Gas mowers can be bought here for about $80 at Walmart. Your $179 battery mower probably won't last too long, wheras a Walmart $80 "special" will run as long as you put gas in it. Battery manufacturing and the associated costs to produce the energy for that process are also more costly to the environment. ( thought I would throw that in)
Old 01-02-2013, 09:21 AM   #14
I cut a fairly big yard with a plug in mower. It worked well, takes a lot longer moving the cord, but, after a few months you learn exactly the pattern to move in and it is not so bad. Nice not having fumes and gas and all that. I would buy a corded one if I still cut my own grass
Old 01-15-2013, 08:46 AM   #15
Rewards Points: 156
I say go reel mower. They are actually lighter and easier to push than a powered mower. You do need to keep actual grass growing though. Reel mowers don't go through stalky weeds and stuff good, they just leave them standing.
av-geek is offline   Reply With Quote
Water heater - Gas or Electric Sartrean Appliances 17 01-13-2012 05:45 PM
90 amp electric car charger! The future... Billy_Bob Electrical 16 02-16-2010 03:01 PM
