Gardening Hose Hardware - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 03-12-2009, 06:35 PM   #1
gardening hose hardware
not exactly sure what it is called or if they even make them, but I need one...
I am looking for a simple piece of hardware that will allow me to mount it to a flat surface, using 2 screws, and would connect directly to the loose end of the hose exactly like the other end attaches to the water source, allowing water to be directly put into a container through a wall or something similar...
here is a simple paint drawing of what I want...
ph7ryan is offline   Reply With Quote
Old 03-12-2009, 07:00 PM   #2
Don't know it all, yet!
Do you want to mount the hose to a wall or to the container? Not quite clear what the supply path is that you want to accomplish from the bracket to the final destination.
If it's worth doing, it's worth doing right. If you wouldn't put your name on it, it ain't done right!
downunder is offline   Reply With Quote
Old 03-12-2009, 08:25 PM   #3
ok....it is actually really complicated but here it goes....
I am competing with my high school in an underwater robotics competition, and I need a way to tether the wires from the bot control box to the control area without letting water into the main container. I figure if a garden hose keeps water in it should certainly keep water out...
I need to mount the hose directly to the side of a 50 caliber ammo box, and have the hose screw on and off of the side, for further portability...
I couldn't really think of a better place to ask this question than a gardening forums so I really hope that you could help...
Thanks...
Old 03-12-2009, 08:32 PM   #4
Rewards Points: 264
Try Lee Valley/Veritas online. Or a marine supply or plumbing supply house.
7echo is offline   Reply With Quote
Old 03-12-2009, 09:33 PM   #5
Rewards Points: 506
Welcome to the forum ph7ryan. Good luck with your work and let us know how it goes. Maybe you could post some pictures when you get time.
gma2rjc is offline   Reply With Quote
Old 03-14-2009, 01:28 PM   #6
There are fittings that you can use on barrels- like to collect rainwater in, etc. to connect a hose to. You drill a hole through the barrel, the fitting passes through with an inside (the barrel) and outside part that seals against the wall of the barrel. Check with hardware retailers.
You don't need any other screws to fasten it with.
Old 03-15-2009, 11:04 AM   #7
Gus
sounds like you need a bulk-head or through wall fitting or tank fiiting. Basically you drill the appropriate size hole place the fitting in the hole and then a rubber washer and large nut is screwed on the other side to form a water tight seal. Then a pipe fitting can be threaded into either end.
Here is an example of one
Bulk Head
Gus is offline   Reply With Quote
Repairing Electric Central Vacuum Hose jogr Appliances 6 11-11-2008 12:59 PM
Bifold door hardware hel handylady Carpentry 1 10-28-2008 06:45 PM
garden hose water spillage questions mcvane Landscaping & Lawn Care 10 07-29-2007 12:27 AM
replacing hose bibb leroyme Plumbing 23 04-16-2007 05:45 PM
Washing machine drain hose morrisp Plumbing 3 09-01-2006 07:24 PM
