Garden Walls - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 05-09-2009, 03:45 AM   #1
sawlucky
Garden walls
Hi there, i have just started remodeling our garden and need to build a wall approx 6ft long x 1 meter high. The problem i have is im not sure which blocks i need to use. Can i get away with lightweight blocks or do i need to use concrete blocks. They will be rendered anyway so my bricklaying wont be seen luckily. Also can i lay them on edge or woukld it be best to lay them flat, it will be holding back a small amount of earth. I have not been a member for long but hopefully this will be a great site for information.
Thanks lucky.
sawlucky is offline   Reply With Quote
Old 05-09-2009, 06:10 AM   #2
You don't say where you are located, but for walls to last, they need a good foundation. If you are in the northern half of the US, that means deep footers, or that wall will shift or fail over time. Since it is not a high wall, you may get by with just digging down and starting with a row of block/stone.
Replace exterior walls or build false walls Medic507 Carpentry 3 11-12-2008 09:48 AM
Straightening Racked Walls smitty286 Building & Construction 3 03-11-2008 08:35 AM
Keeping Water out of the Top of Brick Walls o2barockstar Roofing/Siding 4 02-18-2008 02:50 PM
