Garden Cart Tires??? - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 05-03-2012, 08:48 AM   #1
Rewards Points: 2,152
garden cart tires???
Looking at the popular stores and checking comparison charts. I want a solid tire so it never goes flat.
At a home store found 2 inexpensive carts that state:
solid tire-----yes
flat free------no
If it's solid shouldn't it be 'flat free'?
thanks
I will only be using it a few yrs as I get my shrubs established and don't care about having one last a lifetime.
Startingover is offline   Reply With Quote
Old 05-03-2012, 09:05 AM   #2
Rewards Points: 13,446
If you buy a cheap cart you will regret it.
Soild tires could be plastic rims and soild ruber treads which will crack.
Any cart I've seen with run flat tires has steel rims and is a better trailer because run flats cost more to make.
Have you checked Craigs list for a used one?
Just adding a tube to any tire will go a long way to make it flat free.
It's the made in China tires that always weather crack and leak air.
Startingover (05-03-2012)
Old 05-03-2012, 09:10 AM   #3
A Little Of Everything
Rewards Points: 1,364
solid tire-----yes
flat free------no
thanks
A solid tire IS flat-free. There's no air in it.
Any reason you're not looking into a wheel barrow? Use it, then if you don't want to keep it you can Craigslist it.
DrHicks is offline   Reply With Quote
Old 05-03-2012, 09:44 AM   #4
It seemed the wheelbarrows I viewed had tires that could go flat.
I never paid any attention to whether my dad or hubby ever maintained previous wheelbarrow tires. I just knew they rolled.
Old 05-03-2012, 09:48 AM   #5
I have two wheel barrows with run flat tires, I buy the ones with two tires not just one. Far more stable when loading and rolling.
Old 05-03-2012, 09:59 AM   #6
what are "run flat" tires? I haven't seen that phrase in ads. Does it mean just how it sounds?
Old 05-03-2012, 10:07 AM   #7
There filled with foam not air so they can not go flat.
http://lawn-and-garden.hardwarestore...re-663818.aspx
Old 05-03-2012, 10:46 AM   #8
thanks for the link. Didn't know these existed. Not cheap, but they're what I need.
Old 05-03-2012, 11:02 AM   #9
Another thing you could do - which I did for years with lawn-care tires - is run some Slime in them. I had good luck doing that.
Old 05-03-2012, 11:22 AM   #10
thanks. I just googled 'Slime'.
Old 05-03-2012, 02:37 PM   #11
Just don't dump Slime, or Fix-A-Flat in your car/pickup/motorcycle tires, or you'll eventually have a tire shop employee wanting to rip your head off...
Old 05-03-2012, 04:38 PM   #12
uh, I learned that the hard way with 'Fix a flat' .
add a shower to mobile home garden tub Ray101967 Plumbing 5 01-13-2015 10:18 PM
New lawn + garden - garden is now a swamp Frozinite Landscaping & Lawn Care 8 09-15-2010 07:23 PM
Spring in the Veggie Garden Bushman Gardening Forum 0 05-02-2010 07:03 AM
Underground water line to garden? NateHanson Landscaping & Lawn Care 13 06-11-2009 07:39 AM
Small pneumatic tires not holding pressure Nestor_Kelebay Automotive Repairs 14 04-26-2009 08:39 AM
