Garage Slab And Driveway Gap - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 08-28-2010, 03:18 PM   #1
Garage slab and driveway gap
hello, I'm new to this forum and a new home owner (house is about 35 years old). I have several issues around the house and want to start working on them before it gets too cold out. The first thing I want to tackle is with my garage/driveway. The driveway has seemly moved about 2" away from the garage slab. Second issue is that when it rains or snow melts water comes under the garage door and pools up in the corners. I attached images of both and I am looking for a low cost way to solve these, any ideas will be much appreciated.
Driveway Gap: http://picasaweb.google.com/lh/photo...eat=directlink
Water Issue: http://picasaweb.google.com/lh/photo...eat=directlink
xoix is offline   Reply With Quote
Old 08-29-2010, 02:13 PM   #2
GardenConcepts's Avatar
Rewards Points: 150
Could you use the 2" gap to drain water away from the garage slab? It appears your garage floor slopes the wrong way, so if you could use that gap to drain water away, you may solve the water problem. If you can't direct water from the gap to a spot away from the house, you could try filling the gap with concrete- if you go this route, you'll need to use a membrane to separate the concrete fill area from the garage floor and the driveway.
GardenConcepts is offline   Reply With Quote
Tags
driveway gap , garage door leak
Raising up my garage jimmyfloyd Building & Construction 5 09-17-2009 11:39 PM
Should concrete driveway slab be thinner on the edge by the forms? Studly Building & Construction 6 09-14-2009 10:24 AM
Does a garage REALLY need a slab? tpagel Building & Construction 2 01-30-2008 06:31 PM
Post-Tension Slab Problem Advice/Help Mike McBride Building & Construction 2 01-09-2007 02:51 PM
Sink hole under garage slab. diggitydog Building & Construction 3 08-31-2006 01:49 PM
