Frost Free Hydrant ? - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 06-23-2012, 12:00 PM   #1
frost free hydrant ?
hello , DIY forum i have an outdoor frost free hydrant and when we use the hydrant . the port that drains the water out of the pipe faucet so that it
will not freeze stays open when on but shuts completely off
when off .
so when it is in use there is a-lot of water wasted through the frost free port .
are there a repair for this ? or will the hydrant need replaced ?
thx for any suggestion's very appreciated Raspy
raspy is offline   Reply With Quote
Old 06-23-2012, 12:49 PM   #2
Rewards Points: 13,256
Look on the side for a clamp where the handle attaches to the shaft that opens and closes the water valve.
The old ones where steel and rusted off.
The newer ones are brass.
Sometimes the hex bolt that does the claming comes loose and has moved on the shaft.
Post a picture if the style you have.
There should be a brand name on the handle, look it up on line for direction on your make.
http://www.ehow.com/how_4661373_repa...d-hydrant.html
Old 06-23-2012, 01:26 PM   #3
thx for the quick response , the hydrant is a merrill mfg co ( any flow ) im sure it is over 30yrs old there is a hex
adjustment under the handle .
my question is will the hex adjustment affect the way the frost free port works ? sense the port
is under ground ? i thought there may be debris or something in the pipe keeping the port open .
thx again .
Old 06-23-2012, 01:30 PM   #4
It only has to be off a little bit to stop it from working right.
Look it up on the net, there may even still me a rebuild kit avalible.
Help My Admiral Refrigerator is leaking water Cuwillis Appliances 10 03-25-2014 09:21 AM
Mansfield Frost Free - Drip After Rebuilding TWG1572 Plumbing 0 04-25-2012 03:05 PM
shed frost hydrant leaking underground amakarevic Plumbing 15 03-08-2012 09:52 AM
copper adapter on frost hydrant amakarevic Plumbing 7 07-13-2011 08:27 PM
frost hydrant installation amakarevic Plumbing 5 08-22-2010 03:34 PM
