Front Door Outdoor Light With Flag Spotlight? - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 06-13-2009, 02:05 PM   #1
Just call me Andrew
Rewards Points: 1,020
Front door outdoor light with flag spotlight?
I am looking for a fixture to go outside my front door that also has an additional little light point upwards to light a flag at night.
Does such a fixture exist, or would I need to install a separate light for the flag? Thanks.
secutanudu is offline   Reply With Quote
Old 06-13-2009, 02:08 PM   #2
You could use a dual spotlight & point one up at the flag
But better looking to have 2 fixtures
Possibly having the flag spotlight hidden off to one side
Once my new driveway goes in I will have a spotlight hidden in the garden pointing at the flag
Old 06-13-2009, 02:12 PM   #3
Just call me Andrew
Wow, that was fast thanks. Would this spotlight be located on the ground on one side of my door? How easy it is it to wire it to the same switch as my existing light? I'm no electrician...
Old 06-13-2009, 02:20 PM   #4
It depends upon what you want, layout of door area, electric etc
Some people would just mount one on the wall & point it up
It could be wired to your existing switch
Putting it in the ground I will be running conduit & have a seperate switch
My porch/front door area has a concrete base & rock face
So it's easier for me to pull electric from another area
Instead of having the conduit run down the stone face of the raised front porch
Old 06-13-2009, 02:26 PM   #5
Just call me Andrew
Here's the front of my house...what would you suggest? I'd prefer the light not hit the window to the left, as it is a bedroom.
Old 06-13-2009, 02:28 PM   #6
All brick & concrete - same problem as me
Is that an old spotlight at the center peak?
Is the flag on the right or the left?
Ah...must be left since you don't want it to hit that window
Do you have any outside outlet in the front? or the side?
Old 06-13-2009, 02:31 PM   #7
Just call me Andrew
Well the front of the house does stick out a little where the front door is....so a small spotlight may not actually hit the window...see this picture.
That's actually a flag holder at the peak, hence my thought to put a flag in
Old 06-13-2009, 02:31 PM   #8
Just call me Andrew
whoops. forgot the pic.
Old 06-13-2009, 03:00 PM   #9
Without an overhang the flag would probably be illuminated by the light below. My flag can be seen with just my outdoor light on & the streetlight
Is there an attic?
Doi you have acces to the peaked area from inside?
I see a window on the left, so you should have some sort of access
So a small spotlight off to one side might work, or a decorative (up)light
Old 06-13-2009, 08:44 PM   #10
Just call me Andrew
Is there an attic?
I can have access to the peaked area, but not easily. I should try just seeing if my flag is illuminated with the light I have, that is a good point about no overhang.
Old 06-17-2009, 10:41 PM   #11
Have you considered a solar powered spotlight? Several folks in my neighborhood have them up on the sofits and fascia. Perhaps you could mount one as shown in the attachment. Most home store have a variety of them. You can aim it as needed, and no wiring troubles.
paddlefoot is offline   Reply With Quote
Old 06-18-2009, 07:33 AM   #12
Just call me Andrew
That's a great idea...I guess you don't need much power, a solar one may do the trick. I will look around for one, thanks!
Tile on Front Porch PearlWhiteGT Flooring 8 04-24-2009 02:43 PM
Front Cement Steps / Porch Leaking bschwarz Building & Construction 2 04-14-2009 11:46 PM
Adding new Front Porch, need opinions MeraleeCrowl Remodeling 1 11-05-2008 01:47 PM
Cracked ledger board on front porch King_Doodle Building & Construction 20 06-03-2008 10:16 PM
Raising Doorway Height (load bearing?) treefrog Building & Construction 6 02-25-2008 10:11 PM
