french drain - street curb
Ayuh,.......
It's Probably quite decieving in your picture,......
But,.... Do you know the amount of Fall you have available, from the bottom of the Gate/ Door,.... To the Top of the curb,..??....
From the picture,.....
It appears that if you pull a string line from the top of the concrete at the curb, to a pin at the bottom of the gate,.....
You'd only have to remove a few inches of material about mid, to 1/2 way out, to get the water to flow, Above ground to the curb..............
It'll save ya a 'ell of alot of Work..........
