Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Landscaping & Lawn Care
Old 03-09-2012, 11:20 AM   #1
French Drain pipe under paver patio, how to prevent sagging
I am going to dig two french drain trenches in my back yard. I will build a patio across one of the french drain. I will compact the gravel after I bury the 4" pipe. But I still worry that in the future when I lay the patio the portion directly above the pipe will sag.
Has anybody experienced this?
htabbas is offline   Reply With Quote
Old 03-09-2012, 01:20 PM   #2
GardenConcepts's Avatar
If you use a standard sewer & drain pvc pipe or the black corrugated pipe, you may get some flex on the patio if the pipe is really shallow. In that case, you might look into sdr-35 pipe (available perforated), which has a thicker wall and will be less likely to flex. Either way, the gravel around the sides and on top the pipe, if compacted properly, will distribute the load better than non compacted gravel.
This pic shows solid sdr-35 pipe running under a soon-to-be patio. In this case we had to set the pipe very high, just screeding sand over top of the pipe to set pavers. No flex whatsoever in the surface of the patio for over 4 years now.
Chris
GardenConcepts is offline   Reply With Quote
Adding washer to basement with no way to vent drain pipe General Plumbing 6 12-26-2010 12:11 PM
Tap 2" Drain Pipe into 4" PVC Main Sewer Drain Pipe brmatthews Plumbing 3 12-20-2010 08:49 PM
Basement drain pipe "pit" ground water fix. alecmcmahon General Discussion 13 12-01-2010 06:42 AM
Bubbling in toilet rballard Plumbing 11 08-30-2008 08:15 PM
sewer backup and stench jayhill Plumbing 12 08-14-2008 12:06 AM
